IKF Region 7 - LB
RLV - SS
CR80 Trans Fluid
David McDowell
PostPosted: Thu Feb 21, 2013 10:37 pm    Post subject: CR80 Trans Fluid Reply with quote
I just wanted to check and see if there are any special precautions that need to be taken when changing the trans fluid on a cr80. I thought i read something about it needing to be in neutral but I cant locate it again.
Chris Sigua
PostPosted: Thu Feb 21, 2013 11:33 pm    Post subject: Reply with quote
No need to be in neutral. Just drain and refill.
Only when the checkered flag goes down do I give up. Second means nothing to me - Max Papis
Do or Do Not. There is NO try. - Yoda
CRG Heron - 80 Shifter
DB time: 0.147085 (45.12%), total time:0.325965, queries:38
