Margay Racing
Brett King Design
Tony Kart/Vortex - FB
Know the official name of grooved machine bolt?
Todd Renaud
PostPosted: Thu Feb 21, 2013 1:45 pm    Post subject: Know the official name of grooved machine bolt? Reply with quote
Can't seem to find the "official name" of the bolts that have a groove machined in them at the end of the bolt - commonly found on the areas of the karts (tie rods, pedals, steering columns) that need safety wire per org regulations. These grooves allow the use of the following safety clip (I know where to get these) as shown below:
Anyone a.) know the name and b.) where (bolt house) can I order these types of bolts?
Thanks.
PostPosted: Thu Feb 21, 2013 6:48 pm    Post subject: Reply with quote
Don't know the "official" name of them, they aren't referenced in any of Carroll Smith's books Laughing
But you will probably have to get them from kart suppliers rather than industrial fastener suppliers since I think they come from Italy.
From what I remember Kart Parts Unlimited had both the bolts and safety clips in stock last time I bought fasteners from them. Check with your local kart shop Wink
Cheers,
Heartbeat Power, LLC.
Todd Renaud
PostPosted: Fri Feb 22, 2013 9:10 am    Post subject: Reply with quote
John Matthews wrote:
Don't know the "official" name of them, they aren't referenced in any of Carroll Smith's books Laughing ,
Agree with you there. Carroll is the final "say" on these things. Appreciate the reply.
PostPosted: Fri Feb 22, 2013 12:15 pm    Post subject: Reply with quote
I think technology is running ahead of nameology. I don't think you'll find them from industrial suppliers. I believe they are made on a limited production basis by kart manufactures.
Some of your finer kart shops have drilled bolts for use with cotter pins if you don't like drilling the bolts yourself.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Benn Herr
PostPosted: Fri Feb 22, 2013 12:32 pm    Post subject: Reply with quote
The "Official" name for them is:
"Bolt with a snap ring groove in it near the end".
Birel seems to use them a lot.
You could run down to Harbor Freight and buy one of those little crappy lathes and make your own. Probably be easier than drilling.
http://www.harborfreight.com/7-inch-x-10-inch-precision-mini-lathe-93212.html
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Bill Martin
PostPosted: Sun Mar 03, 2013 11:38 am    Post subject: Reply with quote
heh! That would be a learning experience... I've done a few, when no way to get one in a hurry, but I don't recommend it as a career path. Works much better if you can grind the groove with a tool post grinder.
-bill
Bill Martin
John Mulvihill
PostPosted: Mon Mar 04, 2013 10:25 am    Post subject: Reply with quote
I believe that the proper term is "@#$%^ing bolt that the clip fell off of", or at least that's what I've heard in safety tech.
John
I bowl overhand..........
Benn Herr
PostPosted: Mon Mar 04, 2013 10:56 am    Post subject: Reply with quote
Hah! Very Happy
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
PostPosted: Tue Mar 05, 2013 3:40 am    Post subject: Reply with quote
Here's something funny from the Righetti Ridolfi website, they call them:
USA Type
http://www.righettiridolfi.com/uk/cat/339_345_326_327/usa-type
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
PostPosted: Tue Mar 05, 2013 5:11 am    Post subject: Reply with quote
I guess that's because they don't require safety wire in Italy?
You probably don't need it when you change chassis every other race Laughing
Seriously folks, drilling for safety wire is only hard the first 10 times. After that you just get it done and move on. It's not worth the extra money as far as I'm concerned and proper safety wire is 1000 times better than those little clips IMHO....
Learn how to select and use fasteners properly, the life you save might be your own Wink
Cheers,
PostPosted: Tue Mar 05, 2013 10:59 am    Post subject: Reply with quote
Cheers,
A couple of issues come to mind....
Usually if they are not the "USA Type", they're don't have enough thread past the nut to be able to properly drill. So you end up buying a crap load of hardware to replace the stock stuff.
Some organization don't recognize the "USA Type" fastener clips, they have to be safety wired or cotter pinned....
CR
PostPosted: Tue Mar 05, 2013 11:32 am    Post subject: Reply with quote
Your local tech committee can tell you what's required at your track. From memory all brake hardware, steering hardware and weights should be safety wired. If you're not buying the fancy "USA" type or pre-drilled you're probably looking at ~$25 max to replace all of it plus $10 for drill bits.
Every form of motor racing requires safety wiring AFAIK so learning how to do it right makes sense no matter what.
Read:
You'll be glad you did.
Cheers,
DB time: 0.15122 (41.09%), total time:0.368025, queries:38
