Joined: 13 Aug 2012 Posts: 419 Location: United States, Florida,
Posted: Sat Mar 02, 2013 7:16 pm Post subject: |
Acording to Aixro that's key to developing the power it has.
I'm wondering about a sprocket for one of these. Acording to the manual it uses 428 chain. I don't know what the Axiro guys are running but the largest sprocket I can find in 428 is 30T. I'm sure it's got to be bigger than that.
Brian |
Kai Attwood
Joined: 23 Apr 2006 Posts: 4 Location: United Kingdom (Great Britain), not USA state,
Posted: Sun Mar 03, 2013 1:08 am Post subject: |
Congratulations Brian, and, yes, it has to be bigger than that.
At our tracks I think it’s typically 47-50; one very long track to which we go wants about a 44 and I've heard of - never seen - Aixros running on quite small / tight (= silly) tracks with teeth into mid 50s. So if you're buying only one to start with, probably best to have a 48 or 49.
Check out dedicated Rotary/Wankel forum at karting1.co.uk - very international there. Some people on there will probably also be able to give you reliable conversions; e.g. typical Rotax gearing for a given track = x gearing for an Aixro. |
Posted: Sun Mar 03, 2013 6:19 am Post subject: |
Where are you guys buying 428 sprockets above 30 teeth. Seems like none of the usuall sources have them here in the states.
Brian |
Antoine Marcade
Posted: Mon Mar 04, 2013 4:31 pm Post subject: |
I didn't think to ask but I doubt it. They aren't a karting supplier all they do in the way of karting is the engine packages and parts and they don't stock much.
Brian |
Garett Potter
Joined: 25 Jul 2005 Posts: 29 Location: United States, Louisiana, New Orleans
Posted: Mon Mar 04, 2013 8:17 pm Post subject: |
| Brian Degulis wrote: | Where are you guys buying 428 sprockets above 30 teeth. Seems like none of the usuall sources have them here in the states.
Brian |
We have a full line of 428 sprockets in stock 40-62 for the XR50
Garett Potter
NOLA Motorsports Park |
Antoine Marcade
Posted: Tue Mar 05, 2013 1:32 am Post subject: |
| Garett Potter wrote: |
It is a pretty wide range, with the standard 11 tooth front sprockets I never used lower than 43 and higher than 52 in about 30 different tracks. To use a 40 you need the bi-Aixro I think  |
