SoCal Sprinters
RLV - SS
Franklin / Merlin USA - FB
weight distribution
Matt Hapip
PostPosted: Tue Feb 19, 2013 12:44 pm    Post subject: weight distribution Reply with quote
Please excuse my ignorance as I am new to this. What is the optimal weight distribution in a shifter kart and how can I measure this? I am 5'11 190 and I have a 99 crg daytona heron if that helps.
Take it easy. If you get it easy, take it twice.
Tyson Henry
PostPosted: Tue Feb 19, 2013 12:47 pm    Post subject: Reply with quote
https://www.google.com/search?q=weight+distribution+site%3Aekartingnews.com&oq=weight+distribution+site%3Aekartingnews.com&aqs=chrome.0.57.4770&sourceid=chrome&ie=UTF-8
PostPosted: Tue Feb 19, 2013 1:42 pm    Post subject: Reply with quote
Around 41-43% front weight. You need scales to measure it. A set of nice digital scales is pricey but the best tool. 4 bathroom scales can work as well.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Matt Hapip
PostPosted: Tue Feb 19, 2013 2:01 pm    Post subject: Reply with quote
Thanks guys. Is there a weighing procedure I should mimic for accuracy(four scale weighin) and is weighted tape or just weights ever advisable if maximum adjustment does't yield proper weight distribution?
Joe Ricard
PostPosted: Tue Feb 19, 2013 2:20 pm    Post subject: Reply with quote
Go back to "move the seat"
If you carry ballast move lead locations on the seat.
Arrow AX-8/ Rotax Sr.
PostPosted: Tue Feb 19, 2013 2:48 pm    Post subject: Reply with quote
Factory seat settings are provided to help with weight distribution. You should be able to get it pretty dang close given the factory recommendations.
T.J. Koyen
Exprit/Leopard
PostPosted: Wed Feb 20, 2013 7:44 pm    Post subject: Reply with quote
Make sure your front end is set equally side to side. Any variation in caster camber toe or ride height will effect weight distribution. I used 4 $10 bathroom scales. When I weighed in at the track I was within a few lbs.
Rob Kozakowski
PostPosted: Thu Feb 21, 2013 9:09 am    Post subject: Reply with quote
With bathroom scales, a couple things to keep in mind...
Try to "calibrate" them so that they all give the same (or very close to the same) reading for the same item. Most are "close enough", but sometimes you might get an odd reading on one of them which can set you off in the wrong direction if you're not paying attention.
Another thing to do is make sure the measurement is being taken on a level surface. Pull out a level and adjust scale height / shim as necessary to make sure this is close. This would also apply to the digital scales, though that is probably made a little more self evident when you set them up.
No matter what you're using to weigh, do it with your kart setup as close as you can to how it would be raced (front end aligned the same on both sides, rear track width adjusted equally on both sides, tire pressures at racing pressures, ensuring equal tire circumferences, etc).
If your total weight is alright without ballast, adjust the seat a bit. Factory seat setting should get you close though, so it probably won't need much movement.
If you're underweight (not too likely for your size), and in the factory seat position, you can move ballast.
David Goldman
PostPosted: Thu Feb 28, 2013 7:31 am    Post subject: Reply with quote
CRG has a tuning manual that says they recommend 43% front and 57% rear, but in shifter karts it might be better to have a little more weight percentage in back, maybe 58% or 59% as mentioned. Just as a thought but in some cases it might be better to leave the seat in the manufacturer recommended settings and then add ballast to get the desired weight percentage. You should be close as is, and you might be faster this way even though you would weigh 10lbs more.
joseph hollinger
PostPosted: Thu Feb 28, 2013 9:32 am    Post subject: Reply with quote
If you are buying bathroom scales, its best to avoid the digital ones. Not because they are less or more accurate but because a lot of them shut off after some short interval to save battery life.
Chris Hatch
PostPosted: Wed Mar 06, 2013 7:22 pm    Post subject: Reply with quote
A trick when using bathroom scales is to cut out some 1/4 plywood to cover the scale and limit the deflection. Deflection leads to inaccuracy.
DB time: 0.21384 (47.22%), total time:0.45288, queries:38
