Margay Racing
Tony Kart/Vortex - FB
Spindle lessons
Robert Daniel
PostPosted: Mon Feb 25, 2013 10:00 am    Post subject: spindles Reply with quote
I'm a little confused. Since all steel has essentially the same modulus, spindles made of 1018, 4130, 8620, would all behave the same.
Gary Lawson
PostPosted: Mon Feb 25, 2013 10:24 am    Post subject: re Reply with quote
The big 25mm spindles must be hollow given they are noticeably lighter than a 17mm spindle
kyle luttrell
PostPosted: Mon Feb 25, 2013 10:38 am    Post subject: Reply with quote
Yes those maybe hollow but they are made of a better grade steel. The hollow them to lighten them up.
No a hollow axle isn't stronger then a solid axle if both are made of same material lol [/list]
Kyle Luttrell
www.Luttrellracing.com
Ionic Edge
Kyle@luttrellracing.com
https://www.facebook.com/IonicEdgeChassis
mike clements
PostPosted: Mon Feb 25, 2013 10:54 am    Post subject: Reply with quote
Robert, Those materials you listed act completely different in the real world.
Kyle, I know better. I, and many people before me, have actually tested this theory. I learned this first about 33 years ago when my new Emmick kart came with a solid 1.250" axle. Within a month, they sent me a new hollow axle that was stiffer. The materials were the same according to Gary Emmick. It had a .250" wall thickness. The .188" wall axles flexed too much.
Don't get me wrong. I am not arguing with you. This is common engineering knowledge.
Began kart racing 1959. Made many friends along the way.
kyle luttrell
PostPosted: Mon Feb 25, 2013 11:07 am    Post subject: Reply with quote
Hey,
Well ill tell you want ill do..
Ill get two solid 1'x1" 4130 chromoly and hollow one out and do a test...
Are you a betting man?
500$ to you if the solid one bends before the hollow one ??
Kyle Luttrell
Ionic Edge
mike clements
PostPosted: Mon Feb 25, 2013 11:41 am    Post subject: Reply with quote
How large is the I.D. of the hole ? Remember, we discussed this already.
Here's what you do. You go ahead with your game and I'll go with what I know works. Good Luck to you.
MC
"Began Kart racing in 1959"
"12 years working for GM Engineering staff"
Born into a racing family.
4 National Championships as a driver.
70+ National Championships as an engine builder.
Published author
Holder of 3 U.S. Patents on internal combustion engine design.
World Land Speed Record holder for 4 cycle karts.
You ?
Gary Lawson
PostPosted: Mon Feb 25, 2013 4:45 pm    Post subject: r Reply with quote
I was just stating what may not be obvious to some. No one needs to start puffing chests out. Winter is almost over so we can get back to letting results speak again. The past is over.
kyle luttrell
PostPosted: Mon Feb 25, 2013 4:58 pm    Post subject: Reply with quote
Do you think I just went out and spent 1000's if dollars without testing?
Lol right Smile lol
I don't gamble lol
You are deffantly respected in the go kart industry.
I'm also a ff... A wise chief once told me if you have to tap on your badge/accomplishments then it means nothing.
I don't claim to know it all or have done it all but ill sure die hard trying!
Kyle Luttrell
Ionic Edge
Michael Purnell
PostPosted: Mon Feb 25, 2013 6:13 pm    Post subject: Reply with quote
Mr. Clements,
Please provide us with some sort of references for the theory that a hollow shaft is stiffer than a solid shaft. If it is a "common engineering knowledge" this shouldn't be too difficult for you.
Are you maybe trying to say that a hollow shaft has a better strength-to-weight ratio than a solid shaft? If this is what you are saying than I will agree with you as THIS is a well known engineering principle but your previous posts seem to be stating that a hollow shaft will be stiffer than a solid shaft with the only parameters being that the shafts are of the same material and outside diameter.
If that is what you are saying I respectfully ask for a reference, i think we would all like to see one.
I think that you are confusing strength-to-weight ratio with simply "strength".
mike clements
PostPosted: Wed Feb 27, 2013 11:32 am    Post subject: Reply with quote
oops Embarassed
mike clements
PostPosted: Wed Feb 27, 2013 11:49 am    Post subject: Reply with quote
Very Happy I just noticed that Margay is building a new offset kart for dirt oval racing. Their front spindle arrangement is quite nice and innovative. They also advertise that the material they are using is 8620, just like I did when building mine.
What are you using ?
The only reason I posted anything about past accomplishments is because by far the readers on this site are 2 cycle racers and mostly TaG racers. They are much younger than myself and therefore have no idea as to who Mike Clements is. I am not bragging. When I get as many National wins as Lynn Haddock, Kyle Adkins or Ronnie Emmick, maybe Then I'll brag.
While working for GM Engineering Staff, we used a lot of strain gauges to test various materials and sizes. On sway bars and torsion bars, there is no doubt at all that the hollow tube is stronger and resists twisting more than the solid. NASCAR sway bars and roll bars are tubular as are in just about any form of racing. It's not a weight thing either. If the sanctioning body thought solid was stronger, they would mandate solid.
We did the exact tests you may be thinking of by placing solid bars of steel, various alloys, in a hyd press with a pressure gauge. Apply pressure to them and measure the deflection at the center of the rod. Let's say a 2" diameter for example. Then try a 2" diameter tube of the same alloy. In every case, the tube resisted the pressure better than the solid bar.
Again, I am not going to argue with anyone. My list of accomplishments is my proof. This worked for me and General Motors and NASCAR and Indy Car and Formula 1 and SCCA, etc. You do what works for you and I'll do what works for me.
joseph hollinger
PostPosted: Wed Feb 27, 2013 12:03 pm    Post subject: Reply with quote
You can find an online calculator for tubing deflection here: http://www.calculatoredge.com/civil%20engg%20calculator/beam.htm
I entered the data for two tubes. Both 1" OD and 100" long. Both subject to a 100 pound load. Both steel. One solid, one hollow with a .1" wall thickness. As you can see, the hollow tube bends a lot more than the solid tube.
mike clements
PostPosted: Wed Feb 27, 2013 12:16 pm    Post subject: Reply with quote
Joe, Just for fun, please enter 1.250" O.D. with a .250" wall thickness.
Then compare that to a wall thickness of .188".
These are common numbers for American 1 1/4" axles. Length is 42" for spring racing.
Also, I noticed 70,000 more PSI on the tube as compared to the stress on the solid bar ?
thank you, Mike
joseph hollinger
PostPosted: Wed Feb 27, 2013 12:27 pm    Post subject: Reply with quote
Everything else being equal, the tube with the .188 wall bends about .1 more for a 100 pound load.
The field marked "bending stress" is value calculated to reflect the difference in tension at the top of the tube compared to compression at the bottom of the tube. The more a tube is deflected, the greater than value should be.
bob prinzo
PostPosted: Wed Feb 27, 2013 11:27 pm    Post subject: Reply with quote
id like to know which one of you guys argueing with mike are actual educated engineers.
GP9/leopard no.47
wildkart/HPV1 no.10
Page 2 of 4
DB time: 0.131707 (37.71%), total time:0.349239, queries:38
