SKUSA (non-flash) - LB
DRT Racing - FB
World Formula tag
Brian Spek
PostPosted: Fri Feb 15, 2013 10:06 pm    Post subject: World Formula tag Reply with quote
Anyone know if this engine can go on a Birel 30mm chassis?
PostPosted: Sat Feb 16, 2013 8:25 am    Post subject: Reply with quote
Yes.
Probably.
Check for inboard chain and clutch clearance.
I've found very few European chassis that can't be made to work with 4 cycles. Even changing the rear crossmember isn't as big a deal as you might think.
Cheers,
Heartbeat Power, LLC.
Bernie Lacotta
PostPosted: Sat Feb 16, 2013 4:37 pm    Post subject: Re: World Formula tag Reply with quote
I've seen a lot of WF's on Birel 30's. No problem on the ones I've seen.
I breathe ,therefore,I race
George Vorrilas
PostPosted: Sun Feb 17, 2013 1:03 pm    Post subject: WF - Birel Reply with quote
We just did one on an older Birel EZ kart, worked fine.. I can send pics if it helps..
George V
ApexKartSports
www.apexkart.com
978-479-7974
apexkart@comcast.net (e)
Mitch Wright
PostPosted: Sun Feb 17, 2013 5:24 pm    Post subject: Reply with quote
Yes it will fit on a R30 Birel with a 15* Burris mount.
DB time: 0.209598 (52.78%), total time:0.397121, queries:38
