Tim Brown
Posted: Tue Feb 26, 2013 10:14 pm Post subject: |
| Well I thought with the 50mm stroke it would have a very strong bottom end and wouldn't have to use the L-2, nothing against the L-2, and could try to capture some of that top end hp... is this not the way to do it?? thoughts... |
Joined: 19 Jul 2002 Posts: 4346 Location: United States, South Jerrrsey,
Posted: Fri Apr 12, 2013 7:22 pm Post subject: |
The L4 will give you useable power in a narrow rpm range. If your track has you going from 0 to 60 allot then you're going to be getting max power for a smaller percentage of your lap. What ever advantage the longer stroke gives you won't make up the difference on a sprint track imho.
I've seen the L3 on shorter tracks but they run a high clutch stall, long flex and are careful not to overwind the pipe. I wouldn't try it on less than a 1/2 mile course.
How's the build going, did you get it running? Just wondering if you've had any vibration issues using that crank.
Yamaha KT100 Service Center
40 years karting experience |
Tim Brown
Posted: Sun Apr 14, 2013 10:33 pm Post subject: |
| My first set of cases were not machined very will in the bearing pockets, so the bearing would not go in and the cases were heated to 375. Im taking them in and getting rechecked at a real kart shop, CMC in tigard OR. |
Gordon Duax
Joined: 22 Dec 2009 Posts: 139 Location: United States, Texas, San Antonio
Posted: Thu May 09, 2013 12:23 am Post subject: |
I'm expecting a PRD crank in next week, so I am still very interrested in this thread  |
Posted: Thu May 09, 2013 8:37 am Post subject: |
| Aren't those cranks close to $400? |
Gordon Duax
Posted: Thu May 09, 2013 9:03 am Post subject: |
I found a used one in Japan  |
Tim Brown
Posted: Thu May 09, 2013 10:56 pm Post subject: |
Hey sorry guys that this project isn't move along very fast, got stuck building two engines and a few races, I put way to much on my plate... should be back on it very soon. Its great to see the interest and some actually building their own as we go...that's what this forum is all about!!
My buddy's a Machinist and has too much money and too much time on his hand, so he is machining out Billet kt100 engine cases and maybe billet water cooled heads like the two part Rotax design, great for open classes or practice engines |
Posted: Fri May 10, 2013 7:55 am Post subject: |
| ARC makes a water cooled cylinder that fits right on the KT100. |
Tim Brown
Posted: Fri May 10, 2013 7:42 pm Post subject: |
| Hey there Walt, I think the ARC head mates up with the waterjacket on the ARC cylinder, this would be just the head... |
Posted: Thu May 23, 2013 7:08 pm Post subject: |
Any pics of those billet crankcases? Sounds awesome. Also, what kind of drive system are you using? I understand the PTO is for direct drive or a belt drive and is too short for a clutch.
Chris Parks
Joined: 09 Sep 2001 Posts: 1505 Location: Australia, not USA state,
Posted: Sun Jun 16, 2013 2:36 am Post subject: |
Use head inserts if you have a machinist with the time to make them
http://www.vhm.nl/?navi=cylinderheads
You can set the squish and comp to suit yourself and set the cylinder height where you want it. _________________ understeer happens on road courses and usually is pronounced with a British accent. Push happens on ovals and usually is pronounced through a wad of chew. Other than that, I don't think there's a difference - Jim Derrig
Chris |
