Bondurant - LB
Top Kart USA - SS
KG Plastics - FB
New to Yamaha Pipe Class- Questions
Travis Miller
PostPosted: Thu Feb 14, 2013 6:18 pm    Post subject: New to Yamaha Pipe Class- Questions Reply with quote
I will be moving from Supercan to Pipe this year and unsure what the best clutch/pipe set up is. I run at Circleville Raceway which is a 7/10ths mile track. Any insight into the difference between clutch brands and whether to go with a dry or wet clutch would be appreciated.
Travis Miller
Supercan Heavy
Margay 1.7
Burris Tires
Frankie Schaffier
PostPosted: Fri Feb 15, 2013 10:30 am    Post subject: Reply with quote
RLV L2 or one of the older RLV series pipes (A, G, etc) with the same power range. I saw quite a few RLV Yam pipes at the Springfield swap meet for under $50.
3-disk wet clutch, L&T is probably your best bet. Also quite a few used wet clutches out there from when guys went from wet to dry in the can class.
Frankie
Comet Eagle
Emmick Elite-Parilla TT25
Burris Racing www.burrisracing.com
Stoney Creek Motorsports
Greg Wright
PostPosted: Fri Feb 15, 2013 11:35 am    Post subject: Reply with quote
Are you looking at old style open pipe or the new WKA spec pipe for Yamaha Sr,?
Greg Wright
Rapid Racing Inc.
I AM INDY!!
Frankie Schaffier
PostPosted: Fri Feb 15, 2013 12:02 pm    Post subject: Reply with quote
Howdy Greg,
Pretty sure it's the old verison he after. Circleville has an open pipe class, Yam pipe, KPV 3 pipe and KPV 4... If I remember correct. At times they have a decient turn out for the class, pretty cool.
Frankie
Comet Eagle
Travis Miller
PostPosted: Fri Feb 15, 2013 12:24 pm    Post subject: Reply with quote
Old style pipe - L2.
Travis Miller
Supercan Heavy
Margay 1.7
Burris Tires
Greg Wright
PostPosted: Fri Feb 15, 2013 2:45 pm    Post subject: Reply with quote
OK, Then listen to Frankie, (I don't believe I just said that) I would tell you the same thing that he will.
Greg Wright
Rapid Racing Inc.
I AM INDY!!
PostPosted: Fri Feb 15, 2013 3:25 pm    Post subject: Reply with quote
We had good success using Tomar's big beefy dry clutch in pipe as well. It works good for a lighter class, not sure it would hold up to a heavier class though.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Gordon Duax
PostPosted: Sat Feb 23, 2013 1:39 pm    Post subject: Reply with quote
Find one of the Mayko pipes by Al Nunley.
I finally got in touch with Al a few years ago over on Bob's, and he was able to direct me to the guy who spun the cones, who had some left.
Even though I have a couple of the pipes, I ordered in 2 sets of the cones just to have for future projects.
Matthew Patterson
PostPosted: Mon Apr 01, 2013 12:26 pm    Post subject: Reply with quote
Down here in NO, we're running KTs with L3 pipes in a Super Sportsman class. Usually on 40-60 second long courses, up to 70mph on the straights. We run against some F200s.
We've all been running different clutches (couple wet ones, Patiot 3-disc, Tomar TD-23). So far, the Tomar TD-23 has been working very well for us. I've got one that I've done 2 races (1 total hour racing per raceday) and 2 lapping days, for a total of about 4 hours total racing.
My stall is set at 9300rpm, and I've had less than .002 wear on it.
Curry Brown
PostPosted: Thu Apr 04, 2013 4:27 pm    Post subject: Reply with quote
Im interested in a used yamaha pipe if anyone is looking to sell.
Thanks!
PostPosted: Sat Apr 06, 2013 8:50 pm    Post subject: Reply with quote
Curry you've got a PM.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
DB time: 0.183074 (58.6%), total time:0.31242, queries:38
