Bondurant - LB
*** SOLD *** Tony//Kart Krypton MD/DC
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Kart Packages
Vic Madrid
PostPosted: Wed Feb 13, 2013 2:12 pm    Post subject: *** SOLD *** Tony//Kart Krypton MD/DC Reply with quote
*** SOLD 3/17/2013 ***
Set up for SCCA Solo, with zero events on motor. I had a fun time, but now priorities are shifting to the kids' activities.
Here's what I have, all for $4500:
The Kart:
2006 Tony Kart Krypton 125 chassis
1999 Honda CR125 modified rebuilt top and bottom ends 5/2011, no
events/practices, only run up and down driveway enough to seat ring.
- RCE T3 pipe and M4 titanium silencer with Hegar mounts
- 38mm Keihin PWM pumparound
- stock CDI (see extras, also have PI box and stator)
OTK H (hard) 50mm axle
Tillett ML T8 "hand laid" 1/4 pad seat
OTK AXP wheels with MG Greens
Brand new Shockwave medium front shifter hubs
MyChron 3 Gold with EGT, water, speed, RPM and G-sensor, and 2 emitters
Champion Dual Core radiator
EPIC bypass thermostat - rare, no longer avail and great temp management, no
need for taping radiator.
The Extras:
KartLift stand
Streeter vertical stand for storage
Banke/Vortex programmable ignition and stator if you weigh enough to benefit from this
spare Keihin 41mm PWM pumparound carb
BRLV pipe
Bridgestone Rain set mounted on Douglas aluminum properly narrowed rims
extra OTK MXP wheelset
extra mixed OTK MXP/Freeline magnesium wheelset
2 sets of 1-season-old MG Greens
Turbo Tire changer
RLV bead breaker
Brake bleeder device
Spare cylinder head
Computech Race Air weather station, w/ density altitude
Exac-Toe2 alignment tool with camber gauge and spindle extenders
OTK kart cover
Waterproof blue/white kart cover
Extra front and rear torsion bars for tuning
extra rear sprockets
16T drive gear
Long rear wheel hubs
OTK short front hubs
Spare Tony//Kart steering wheel
extra seat struts
extra lead weights
spare cylinder head
spare bolts/fasteners
fluids and lubricants
spare radiator hose
extra fuel line
extra lead puck (if you need this you won't need the PI ignition)
Wheel weights for balancing
extra new NGK spark plugs
custom length, one of a kind blue nylon starting strap (ha ha)
whatever else I find that is kart-specific
- Vic
- SCCA/WDCR F125 #54
- 2006 Tony//Kart Krypton 125
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Kart Packages All times are GMT - 8 Hours
DB time: 0.147966 (44.05%), total time:0.335882, queries:38
