OTK - LB
Streeter - SS
Franklin / Merlin USA - FB
93 pump fuel???????
Goto page 1, 2  Next
marc walsh
PostPosted: Mon Feb 11, 2013 4:23 pm    Post subject: 93 pump fuel??????? Reply with quote
Race Gas is getting pricy. Rotax Max only requires a max rating of 93. Has anyone seen a difference in performance or issues with a good Gas/eth mix like Amaco or equivalent?
jeremy shaw
PostPosted: Tue Feb 12, 2013 12:17 pm    Post subject: fuel Reply with quote
Go to page 2 on rotax forums and its halfway down titled rotax fuel. there was a lot of good debate on using 91 93 and racing fuel.
PostPosted: Tue Feb 12, 2013 8:32 pm    Post subject: Reply with quote
I would stay away from ethanol it destroys everything it touches.
al nunley
PostPosted: Wed Feb 13, 2013 6:33 am    Post subject: Reply with quote
Don’t know if you know what “octane” is, but you would think the maker of the engine would know what is best for their engine.
Octane is just a measure of a fuels ability to resist detonation, so “if” your mixture is right, and you’re not getting detonation, 93 octane should be just right. More octane will “not” help performance.
I like the EGT for checking mixture. Get the highest reading you can, on the low end, as well as on the top end.
Chad Hartzell
PostPosted: Wed Feb 13, 2013 1:52 pm    Post subject: Reply with quote
Ran ethanol based pump fuel @ 93 Octane last year for the MRP series. No problems whatsoever with anything from fuel line, to fuel pump, gaskets, etc... The key is thoroughly draining it all at the end of the race day.
We had to change main jet (richer) and float heights a little bit compared to the VP MS 93 we used to run, but nothing that proper testing and tuning can't solve.
I've got no issues with it and look forward to running it again this year.
Chad Hartzell
Russell Stevens
PostPosted: Wed Feb 13, 2013 2:45 pm    Post subject: Reply with quote
1: As long as you are draining it every day ethonol is fine
2: As long as you are not running on the edge of lean ethenol is fine
3: As long as you have a fuel supplier who is consistant with the ethenol content, running ethenol is fine.
If the ethenol content changes, and you are running on the edge of lean... boom...
Just run 91 straight gas and you will be fine. The Rotax doesn't have enough compression to really require a higher octane.
Ethenol is hydroscopic, and corrosive. Talk to a local small engine repair shop about the effects on aluminum carbs.
If you must run E-gas tune conservatively, and add Green (marine) stabil if you are allowed.
PostPosted: Wed Feb 13, 2013 4:35 pm    Post subject: Reply with quote
Yeah I guess if you want to adapt to it you can make it work but why?
Jim McMahon
PostPosted: Sun Mar 17, 2013 8:32 am    Post subject: Reply with quote
Buy your gas from a marina and call it a day. Pump fuel can be a mixed bag in terms of content. Its not the octane thats the problem, its the changing composition. If you are talking about a sealed rotax motor I don't think I'd risk it on pump if a good marine source could be found.
Reasoning is that good marine fuel contains zero ethanol.
If you are stuck with pump then you hedge your bets by buying from a station with high fuel turnover and try and buy as soon as they have had their underground tanks toped off.
Or just run whatever comes out of the pump, whenever and hope you don't blow up.
CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online
Cory Ross
PostPosted: Tue Mar 26, 2013 9:04 am    Post subject: Reply with quote
If you talk to BRP the Rotax engine has been tested and is ready to use up to to 10% ethanol fuel. Sure you could still have the problems of ethanol absorbing water but as for it eating engine parts it is not much of a problem. I have been using fuel with ethanol for the past 4 months(15 running hours) and have not drained my tank or anything after using the kart. Everything in the carb and elsewhere is showing no signs of being eaten by the fuel. Carbs in older small engines do get eaten by ethanol but that is because they were not designed to run it in the first place.
Peter De Saegher
PostPosted: Tue Mar 26, 2013 3:15 pm    Post subject: Reply with quote
Cory , do you notice a big gain in ^power using ethanol in your Rotax ?
Cory Ross
PostPosted: Wed Mar 27, 2013 5:48 pm    Post subject: Reply with quote
The first day I ran the kart I used VP MS93, then I switched to Shell 91 from the pump and did no really notice any difference.
Cory Ross
PostPosted: Mon Apr 08, 2013 8:07 am    Post subject: Reply with quote
Was talking with another racer yesterday with a lot more experience then me. He says his Rotax runs much better on Shell 91 then it does on VP fuel.
Nick Weil
PostPosted: Mon Apr 08, 2013 4:23 pm    Post subject: Reply with quote
Not sure who you spoke to at BRP, but the people I know and respect don't recommend running it at all. Ethanol is just a poor decision all around when it comes to a race engine. It destroys rubber component (o-rings, gaskets, seals) and it doesn't deliver a boost in performance. A lose/lose situation. Except if you can't afford to be racing to begin with.
Nick Weil
Want to save money AND grow the economy? www.fairtax.org
Cory Ross
PostPosted: Mon Apr 08, 2013 6:54 pm    Post subject: Reply with quote
I talked to tech support from BRP website. I cannot remember the name of the person I was talking to. I do know they were from Europe.
Salvie Zaccaria
PostPosted: Sat May 11, 2013 7:37 pm    Post subject: Reply with quote
Rotax engines run very well on pump fuel and at that savings in cash what would it matter anyway. We always practiced on pump fuel and were forced to buy expensive race fuel on race day. The jetting changes slightly but it's no big deal. Just another way for the track to make money selling race fuel.
Salvie Sr, Zanardi #7 and #8
F1 Boston
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.16366 (40.91%), total time:0.400029, queries:38
