Ocala Gran Prix - LB
MRP - SS
DRT Racing - FB
Exac Toe 2 - Do Spindle Extensions it fit 25mm spindles
Chad Hartzell
PostPosted: Mon Feb 11, 2013 12:28 pm    Post subject: Exac Toe 2 - Do Spindle Extensions it fit 25mm spindles Reply with quote
Bought a used Eac Toe 2 last year and never used it because it didn't fit the spindles on my '12 Birel R32.
Do the spindle extenders Odenthal makes come in a size large enough for those types of spindles?
Thanks!
Chad Hartzell
Randy Mckee
PostPosted: Mon Feb 11, 2013 4:43 pm    Post subject: Reply with quote
I'm not certain, but I think most 25mm spindles use a M14 nut. The exac toe extenders come in 14 and 16mm versions, so I'm pretty sure it works.
If you take a look at Accelaration's page for exac-toe, it says "If you have the new 25mm spindle you will need the spindle extenders."
http://www.accelerationkarting.com/exac-toe2withxbar.aspx
Randy
Peter Zambos
PostPosted: Mon Feb 11, 2013 9:22 pm    Post subject: Re: Exac Toe 2 - Do Spindle Extensions it fit 25mm spindles Reply with quote
yes
Chad Hartzell
PostPosted: Wed Feb 13, 2013 1:54 pm    Post subject: Reply with quote
Thanks, Peter. Do you know if it is the 14 or 16mm? My kart is at the track in storage so I can't go check..
Chad Hartzell
Peter Zambos
PostPosted: Wed Feb 13, 2013 2:42 pm    Post subject: Reply with quote
Ours is 14mm. I don't know for sure what size nut goes on the end of a Birel stub axle, but nearly all of them are 14mm.
PostPosted: Wed Feb 13, 2013 3:00 pm    Post subject: Reply with quote
Chad,
You've at least three options. Contact a shop that deals with your type of chassis. A good place to start might be MRP Motorsports for you. Or you could download the parts manual for your kart to see what size nut is used. Or get the kart out of storage and measure your spindles. No doubt that way. Or you could order both the 14 and 16 mm extenders and send the wrong set back. Oops, that's four. BTY-We use the 14's.
ap kart racing
L.A.D Specialties
DB time: 0.16798 (47.36%), total time:0.354688, queries:38
