SoCal Sprinters
Russell Karting - SS
Rotax engine issue
Carlos Plaza
PostPosted: Mon Feb 11, 2013 10:22 am    Post subject: Rotax engine issue Reply with quote
I just rebuilt my rotax. Put new seals and bearings in the case piston,rod and cylinder head. I didn't mess with the reeds or carb. They were working fine before. When I try to start it I have to use the choke or it won't start at all. And about 15 to 30 seconds after it fires it revs to 8000 on its own. I've checked the throttle to make sure it wasn't that. I know that the piston has to go in a certain direction. I've already tired it both ways but still does the same thing. Also it seems to be pushing some oil in the line that goes from the crankcase to the fuel pump. It never did that before. Any help would be great. Thanks.
Greg Wright
PostPosted: Mon Feb 11, 2013 11:39 am    Post subject: Reply with quote
Air leak, could be crank seals or ????
Greg Wright
Rapid Racing Inc.
I AM INDY!!
Joey Guyon
PostPosted: Mon Feb 11, 2013 6:11 pm    Post subject: Reply with quote
You might have installed the seals on the wrong side. The balance gear side seal is larger I.d. if it is on the opposite side there will be huge clearance. You can spray the clutch seal with wd 40 and it will bubble if incorrect. The engine will also be harder to turn by hand as the clutch seal will be super tight on the balance side.
Or your slide is in backwards and isnt closing.
DB time: 0.265485 (56.38%), total time:0.470899, queries:38
