2D2W - LB
Top Kart USA - SS
different width with new wheels affect on handling
marc-andre hubert
PostPosted: Sun Feb 10, 2013 4:24 pm    Post subject: different width with new wheels affect on handling Reply with quote
i installed another set of wheels on daughter cadet, and i left the small hubs on axle, and the offset is different so rear widht is 1 " shorter..
Now axle Stiffeness is unchange since hubs did not go inwards, but im 1" shorter, how will it affect handling VS older wheels and pushing rear hubs .5" each side.
marc-andre hubert
PostPosted: Tue Feb 12, 2013 8:08 am    Post subject: Reply with quote
no one as install different wheels wich gave them different width?
PostPosted: Tue Feb 12, 2013 8:46 am    Post subject: Reply with quote
Will have the same affect as stiffening the axle, just not as much as if you were to actually narrow the rear track width.
Will give the kart a bit more "dig" and more rear side bite.
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
marc-andre hubert
PostPosted: Tue Feb 12, 2013 9:16 am    Post subject: Reply with quote
thanks so adds a bit of bite but not as much. good too know, been going narrower and turning alot better, so will see if it helps some more thanks
DB time: 0.131123 (41.61%), total time:0.315149, queries:38
