Peter Zambos
Joined: 22 Jun 2006 Posts: 538 Location: United States, Illinois, near Chicago
Posted: Mon Feb 18, 2013 2:25 pm Post subject: |
| Jim, sadly my "lead" is affixed rather firmly to my middle. It's not going anywhere! |
Chris Sigua Moderator
Posted: Mon Feb 18, 2013 8:07 pm Post subject: |
What pressures do you run on R60's? _________________ Only when the checkered flag goes down do I give up. Second means nothing to me - Max Papis
Do or Do Not. There is NO try. - Yoda
CRG Heron - 80 Shifter |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2657 Location: United States, St. Paul,
Posted: Tue Feb 19, 2013 6:33 pm Post subject: |
| Chris Sigua wrote: | | What pressures do you run on R60's? |
I usually start around 10-12 cold when track temps are higher, up to another two lbs on top of this if the track is cold or particularly green. That's with a 125 shifter weighing in around 410-415lbs. YMMV. _________________ GPI Racing | WildKart | Maxter | Hoosier
Karting Festival @ Blackhawk Farms June 1st-2nd. |
Posted: Tue Feb 19, 2013 7:48 pm Post subject: |
Thanks Jim. I'll be on an 80 shifter at about 300-310lbs. No lead on the kart. _________________ Only when the checkered flag goes down do I give up. Second means nothing to me - Max Papis
Jim McMahon
Posted: Wed Feb 20, 2013 10:31 am Post subject: |
| Chris Sigua wrote: | | Thanks Jim. I'll be on an 80 shifter at about 300-310lbs. No lead on the kart. |
Start with 12 "cold", adjust depending so that your hot pressures are no more than 2psi elevated from cold. With 100lbs less you might be going higher than 12 starting, but your PSI affects your spring rate too. Play around, they seem to have a nice wide spread of tolerance. _________________ GPI Racing | WildKart | Maxter | Hoosier
Chad Landers
Joined: 01 Oct 2004 Posts: 303 Location: United States, Wisconsin, Plover
Posted: Thu Feb 21, 2013 5:38 am Post subject: |
I ran Hoosiers back around 06 or so when they first got back into sprint racing. I ran them enduro racing in Tag for a few years.
One thing I did notice is that the bead on the tire was pretty stiff and they were harder too mount than Bridgestones. Had to get them pretty hot to get mounted easily. But the sidewall was soft.
My brother also ran the Hoosiers and I remember watching his front tires flex and sway back and forth at the sidewalls at Road America. It was crazy to see the contact patch stay planted, but the side wall flex back and forth.
I never noticed this or felt this handling wise on the kart. I did like how long the Hoosiers lasted though. They might not have been the fastest initialy, but they seemed to last twice as long for me. I did a lot of sprint practice on old sets and I thought they worked good.
I have been running MG Yellow's and Dunlops for the last couple of years and even Bridgestones. The Bridgestones don't seem to like the longer heat cycles compared to sprint racing. They seem to work better for me when they are older tires that I sprint raced with for a weekend. When I would put a new set on for a race they would be pretty slick toward the then end of the race.
The Yellow's were always good and one of my favorites. However I will be going back to the Hoosier's this year and trying this stiffer sidewall version. Even if the sidewall is softer I'd probably still run them due to how long they lasted. _________________ Laukaitis Racing Engines
Need Airbrushing work for a Helmet or Custom T-shirts
Check out Custom Creations www.cc-airbrush.com |
Josh Buttafoco
Joined: 03 Nov 2010 Posts: 125 Location: United States, California, santa rosa
Posted: Fri Mar 08, 2013 12:50 pm Post subject: |
| The new Hoosiers arrived yesterday and almost sold out the same day. Same R60 marking on the side. I ll be testing the new construction on Monday. |
