Bondurant - LB
MG Tires - SS
KG Plastics - FB
CRG RS4 and RS5
Mike Wood
PostPosted: Thu Feb 07, 2013 9:16 pm    Post subject: CRG RS4 and RS5 Reply with quote
Wondering about these chassis (especially RS4). There's very little out there in the WWW about them. Are they used with success? Thinking about WF on one.
Cheers,
Mike.
GP8 CRF250R shifter
Top Kart clone (for the dirt oval!)
PostPosted: Fri Feb 08, 2013 7:55 am    Post subject: Reply with quote
Should be a fine chassis for World Formula. CRG knows what they're doing and starting with something engineered for 4 cycle will make it easier to get dialed in.
Do you have a line on a used one or are you buying new?
Cheers,
Heartbeat Power, LLC.
Mike Wood
PostPosted: Fri Feb 08, 2013 8:33 am    Post subject: Reply with quote
Thanks - yeah I see a used 2011 RS4. I guess they updated quite a bit after that with the 5. I am a bit nervous about the 28mm tubing. I am 175lb 6' and want to use it on both grippy and less grippy tracks. There are a lot of CRGs around here though for support - if it still uses common parts.
GP8 CRF250R shifter
PostPosted: Fri Feb 08, 2013 10:43 am    Post subject: Reply with quote
I wouldn't worry to much about the 28mm tubing, it should still be plenty strong. CRG or aftermarket parts will work fine, just make sure you buy it right so if it doesn't work out for some reason you can throw a clone on it and sell for a profit Wink
Cheers,
DB time: 0.078914 (43.58%), total time:0.181087, queries:38
