SKUSA (non-flash) - LB
K1 Speed - SS
Mychron Battery life
Ray Lovestead
PostPosted: Thu Feb 07, 2013 6:41 pm    Post subject: Mychron Battery life Reply with quote
I find that my batteries go dead way faster than they should. Has anyone check the current draw when 'off'? I suspect that 'off' isn't truly so.
I was thinking of putting in a switch to disconnect the batteries. Would that kill the memory?
Ray
"Karting Expert Since 2014"
Jim McMahon
PostPosted: Fri Feb 08, 2013 7:23 am    Post subject: Reply with quote
Memory is flash/NV so if you cut the power it will keep everything in there. There might be a parasitic loss of sorts but before you go putting switch in there, have you been using Li batteries? If not, I would suggest that first.
patrick slattery
PostPosted: Fri Feb 08, 2013 8:42 am    Post subject: Reply with quote
If your running a GPS with no outside battery source, you can expect high consumption rate.
gregg boyce
PostPosted: Fri Feb 08, 2013 10:00 am    Post subject: Reply with quote
Get some 9v lithium batteries. They'll last longer and they're lighter so they'll improve your C.o.G. Laughing
GB
Seriously, though I used these I was quite happy with them
Ray Lovestead
PostPosted: Fri Feb 08, 2013 10:26 pm    Post subject: Reply with quote
no GPS. I'll try the lithium batteries next.
Thanks guys.
Mike McKnight
PostPosted: Wed Feb 13, 2013 1:30 pm    Post subject: Reply with quote
Ray there have been several firmware updates to the M4 and at least one of them addressed battery management. You may need to update it if you have a key or send it to us for updating.
Mike
Ken Schilling
PostPosted: Wed Feb 13, 2013 2:55 pm    Post subject: Reply with quote
I'm not trying to be a smart alec but... Laughing
Make sure to manually turn it off when you come off track or any other time the engine isn't running. While yes, it will turn itself off automatically when it sits without any input (meaning RPM), you can save those few minutes by turning it off yourself.
Also, no need to manually turn it on as it automatically turns on when you start the engine.
Ken Schilling
SKUSA Data Administrator
DB time: 0.119858 (52.95%), total time:0.226374, queries:38
