Randy Mckee
Posted: Tue Feb 05, 2013 7:55 pm Post subject: Crankcase hosed |
Looks like I dodged a bullet. This is the left side crankcase half near the main bearing. Other side looks fine. Have you guys seen this before? Ideas as to cause?
 _________________ Randy
#123 TonyKart - S4 Stock Honda |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2787 Location: United States, St. Paul,
Posted: Tue Feb 05, 2013 9:37 pm Post subject: |
Yuk! Porosity? _________________ CES Grattan pre-entry is open. TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart.
Click Here to enter Grattan online |
Benn Herr
Randy Mckee
Posted: Wed Feb 06, 2013 12:38 pm Post subject: |
It is a curiosity. I think the bearing is the original, because this is the first bottom-end rebuild. I did have a motor mount failure at the front, and ran it an entire heat race with the motor vibrating like crazy. Ran fine and have run it for 2 years since that incident.
The cracks don't go all the way through, however there are similar cracks on the outside (but in a different spot).
Just wondering if anyone has seen this before. Just a bad case of a bad case? _________________ Randy
Christian Hubbell
Joined: 01 Feb 2006 Posts: 236 Location: United States, Michigan, Waterford
Posted: Wed Feb 06, 2013 6:49 pm Post subject: |
| I'd say ice but water shouldn't be in there. |
