SKUSA (non-flash) - LB
RLV - SS
Tony Kart/Vortex - FB
PRD Gearing
PostPosted: Sun Feb 03, 2013 3:39 pm    Post subject: PRD Gearing Reply with quote
Does anyone know a starting point for PRD gearing. It's got the standard 11 T clutch. I just want to get in the ball park before going to the track.
Matt Koerner
PostPosted: Sun Feb 03, 2013 3:52 pm    Post subject: Reply with quote
Gearing is different for every track. What track are you going to?
Racing is life. Everything else is just waiting.
PostPosted: Sun Feb 03, 2013 7:17 pm    Post subject: Reply with quote
Anderson but just trying to get in the ball park. Rotax would run around 12/80 there.
Andy Seesemann
Expert
Expert
PostPosted: Sun Feb 03, 2013 7:47 pm    Post subject: Reply with quote
Brian,
This may be a trick question. 95% of PRD users are part of the Spec PRD program which uses the small carb and a spec gear. In SoCal, the spec gear for Spec PRD Sr. is 81 +/- 1 tooth. They do not have the flexibility in gearing as many other classes.
Start there.
A
Andy Seesemann
FULL THROTTLE KARTING
Orange County, CA.
www.fullthrottlekarting.com
Rotax Challenge of the Americas
www.rotaxchallenge.com
WKA District 10 Trustee
www.worldkarting.com
Really Good Guy.
PostPosted: Sun Feb 03, 2013 8:13 pm    Post subject: Reply with quote
Thanks that's a start. I'm using the large carb and not running the spec PRD class we just run TAG with a weight advantage.
gregg boyce
PostPosted: Mon Feb 04, 2013 9:42 am    Post subject: Reply with quote
Brian,
Never been to Anderson but NCMP would be ~ 11/77 for Leopard and ~11/75 for PRD.
I would take the lepard gearing for Anderson and drop 1-2 teeth.
GB
PostPosted: Mon Feb 04, 2013 10:08 am    Post subject: Reply with quote
That's logical. It's got an 83T rear sprocket now and just running down the street it feels like the ratio is to high. I'll have to get to the track do the break in and figure it out from there but I'm guessing around 78-79 is proubably where I'll end up.
DB time: 0.427372 (63.66%), total time:0.671331, queries:38
