MaxSpeed - LB
DRT Racing - FB
spindle/stub angle
Jake Rathert
PostPosted: Sun Feb 03, 2013 1:12 pm    Post subject: spindle/stub angle Reply with quote
What angle are most axle spindles/stubs? Changing the angle only affects camber, not caster correct? I am looking for used spindles (with front brakes) on ekartingnews and don't want to run into setup and handling issues because the spindle angle changed. Thanks for the help
Jake
Peter Zambos
PostPosted: Sun Feb 03, 2013 1:48 pm    Post subject: Reply with quote
I can't speak to all of them, but those that I have used have been in the 10 to 11 degree ballpark, with most being either 10.25 or 10.5.
You are correct that the angle effects only camber. The higher degree value will allow you to get the same realized camber at the wheel with a greater negative camber at the kingpin. I've never done a back-to-back comparison, but I would think that the greater angle would create a front end which is more sensitive at initial turn-in, and would also get greater weight jacking through out the turn. Remember, though, too much of a good thing does really exist.
DB time: 0.407215 (82%), total time:0.496585, queries:38
