Bondurant - LB
Russell Karting - SS
SCCA Enterprises - FB
CR125 water pump question
Todd Kageals
PostPosted: Sun Feb 03, 2013 7:07 am    Post subject: CR125 water pump question Reply with quote
Does anyone know if the updated water pump with the metal gear fits the 1994 CR 125? The one I am rebuilding on my spare motor has a questionable shaft (grooved). Fastech sells only 1 for the CR125 but they don't specify which years it will fit.
Ray Lovestead
PostPosted: Tue Feb 05, 2013 2:08 pm    Post subject: Reply with quote
I don't know the answer to your question. But I DO know that you most definitely should not use that grooved shaft. I used one once, and it leaked water past the bearings and seals and got water into the bottom end and caused a big mess of things.
"Karting Expert Since 2014"
Sam Zavaglia
PostPosted: Tue Feb 05, 2013 2:54 pm    Post subject: Reply with quote
I thought plastic one is CR250 and metal one is CR125, either one will fit.
http://sharkshifter.com/zc/index.php?main_page=index&cPath=88_128
www.samzavaglia.com
PostPosted: Wed Feb 06, 2013 5:58 am    Post subject: Reply with quote
The early years 125 did come stock with the plastic gear, and when they shred all the teeth off, the plastic doesn't contaminate the oil!!! Shocked
Yes, the later metal gear shaft should fit the earlier cases....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
DB time: 0.292776 (66.06%), total time:0.443194, queries:38
