Josh Hovermale
Posted: Thu Jan 31, 2013 12:33 pm Post subject: Whats the secret? -- Pulling spindle/king pin bearings -- |
As the title states, I'm pulling, or at least trying to pull out my spindle bearings. Knocking out the front hub bearings was easy. The spindles are another story.
I pushed the spacer to the side and I've tried using a screw driver, and then a punch to knock them out, with no luck. The bearing is only 8mm, so its hard to find something that fits at the proper angle to really do the trick. My punch barely fits, so it really isn't doing much. I try to be as DIY as possible so any advice is welcome. |
Joined: 04 Dec 2004 Posts: 1995 Location: United States, Michigan, Williamsburg
Posted: Thu Jan 31, 2013 12:35 pm Post subject: |
Heat.
Get a cheap hotplate, set it on high, heat that baby up, then try pushing them out.
Wear welders gloves
Heartbeat Power, LLC. |
Scott Heavin
Joined: 18 Oct 2006 Posts: 1766 Location: United States, Indiana, New Castle
Posted: Thu Jan 31, 2013 12:51 pm Post subject: |
I've never been able to get them out without destroying them so I just beat them out with a punch and hammer and not worry about it. I've seen people remove them gently and without damage, but I figure the only time I need to remove them is if they're bad and need to be replaced anyhow. _________________ Spec TaG Masters @ NCMP / #23 |
Tyson Henry
Joined: 10 Aug 2011 Posts: 349 Location: United States, Texas, Arlington
Posted: Thu Jan 31, 2013 2:14 pm Post subject: |
| I have had very good luck with the beat the crap out of 'em method. |
Ken Schilling
Posted: Thu Jan 31, 2013 3:57 pm Post subject: |
| Scott Heavin wrote: | | I've never been able to get them out without destroying them so I just beat them out with a punch and hammer and not worry about it. I've seen people remove them gently and without damage, but I figure the only time I need to remove them is if they're bad and need to be replaced anyhow. |
Just be careful to not damage the bearing seating area... _________________ Ken Schilling
SKUSA Data Administrator
The opinions I express are mine alone and do not reflect those of any organization of which I am a member. |
Mark Erpelding
Joined: 27 Dec 2007 Posts: 139 Location: United States, Indiana, Ft Wayne
Posted: Fri Feb 01, 2013 12:23 pm Post subject: SPINDEL BEARINGS |
A BFH and a punch has always done the trick for me at the track. If I was home I would use a press.. _________________ We spend our money on Racing, Whiskey, and Women ~ The rest we waste! |
Joined: 19 Jul 2002 Posts: 4304 Location: United States, South Jerrrsey,
Posted: Fri Feb 01, 2013 12:57 pm Post subject: |
You should use a long 1/4" drift punch but, you should have the proper tool to back up the spindle or you could cause damage. Of course you'll need new bearings.
Yamaha KT100 Service Center
40 years karting experience |
Mike Goebel
Joined: 28 Jul 2001 Posts: 5766 Location: United States, California, Winnetka
Posted: Sat Feb 02, 2013 6:37 am Post subject: |
Just beat the **** out of them!
mfg Technology Centre
