OTK - LB
MG Tires - SS
Franklin / Merlin USA - FB
PVP.. front end alignment ??
Jeff Metter
PostPosted: Thu Jan 31, 2013 7:13 am    Post subject: PVP.. front end alignment ?? Reply with quote
I am planning on running a PVP at Roebling Road and other than eyeballing the front end alignment will any of the Sniper old style or V2 work without the laser hitting the Caster /Camber uprights ???
Any suggestions ??
Zanardi/ TM K-9 C 125cc shifter
Anderson /GasGas
PVP / GasGas
" We never really grow up " !!
" We only learn how to act in public" !!
Bobby Butler
PostPosted: Thu Jan 31, 2013 9:00 am    Post subject: laser Reply with quote
Hey Jeff, thought about you at Daytona each time I went by turn 5 !! Ha!
Try shooting the laser under the kart....works for me.... Confused Confused
Bobby Butler......."GO BOY GO" RACING, HOUMA, LOUISIANA
250 Twin PVP / Anderson
John Benson
PostPosted: Thu May 09, 2013 4:52 pm    Post subject: Reply with quote
Hi all,
this looked like a good place to ask this. How do you know when you have to much castor?What will the kart do or act like? My PVP is like driving a truck with no power steering! I have the wt close at 37% on the front ( 91lbs lt 90 rt ) camber 3deg positive( unloaded), tires look good 10psi in the front 14 in the rear. 1/32 toe out. I was running dunlops and thought that was the problem but went back to b-stones and only a little better. Evil or Very Mad It feel OK on high speed stuff ( I have the nose all the way down )slow speed is bad rt or lt .Thanks for any input, John.
Ian Harrison
PostPosted: Thu May 09, 2013 5:27 pm    Post subject: Reply with quote
Hi John
Your comment regarding ultra heavy steering indicates that you are running a lot of castor (or need to visit the gym Wink ).
3 degrees of positive camber is too much as well and serves to magnify the problem. Set your "hanging camber" to 1 degree pos as a start.
The effect of castor is to unweight the inside rear wheel by twisting the chassis as the lock is applied. You can see how much by observing the behaviour of the chassis as you wind the steering from lock to lock on a flat patch. Too much castor will also knife edges the tyre in the turn, so typically you feel good initial turn in bite. You will then see decreasing grip towards the apex when application of further lock and throttle will see you loosing back end grip.
Conversley, too little castor makes the kart too flat and will tend to give a light "wooly" feel to the steering accompanied by an impresive level of understeer (push).
You need to try some structured track testing were you can make an adjustment, do a couple of laps, come in and make another adjustment, etc, etc. You will quickly learn how and what to adjust and by how much to make your chassis work.
Best Regards
Ian Very Happy
Ian Harrison
Viper Racing UK
www.viper-racinguk.co.uk
sales@viper-racinguk.co.uk
+44 7984 225 564
+44 161 343 2009
John Benson
PostPosted: Thu May 09, 2013 5:48 pm    Post subject: Reply with quote
Thanks Ian,
I started with 1 deg + camber and 19 castor and it was eating up the inside fronts. Ended up at 3 and 23 with no real change but to be honest that was before I had the wt right. Has anyone ever solid mounted the rear bumper?Bad idea? Also I don't think I've ever felt WOOLY ! Shocked John.
Ronald Kuhn
PostPosted: Thu May 09, 2013 7:24 pm    Post subject: Reply with quote
I use the setup info on the PVP website, and mine handles like it's on rails.It gives you caster and camber angles tire pressures and wet setups also.
Bobby Butler
PostPosted: Thu May 09, 2013 7:52 pm    Post subject: Set up Reply with quote
Gees Ian,
Just when I thought I had this sort of stuff figured out you come along and wreck my train. Now I ll spend another sleepless nite deciphering your post.
BTW, Poul has the base line settings on the PVP site.
Still waiting for your next visit...Daytona 2013???
DB time: 0.267123 (58.15%), total time:0.459406, queries:38
