SKUSA (non-flash) - LB
MRP - SS
Oxegenated Fuel
PostPosted: Tue Jan 29, 2013 1:35 pm    Post subject: Oxegenated Fuel Reply with quote
Anyone using oxegenated fuel? If so why or why not?
Greg Wright
PostPosted: Tue Jan 29, 2013 2:06 pm    Post subject: Reply with quote
Won't pass tech.
Greg Wright
Rapid Racing Inc.
I AM INDY!!
Jeff DeMello
PostPosted: Tue Jan 29, 2013 3:11 pm    Post subject: Reply with quote
In mod you can
Jeff DeMello
Emmick F125 Pavesi
PostPosted: Tue Jan 29, 2013 7:22 pm    Post subject: Reply with quote
I don't think so... Open fuel can not use Oxygenates.... I don't have a rule book in front of me, but that was always the rule...
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Jim McMahon
PostPosted: Tue Jan 29, 2013 9:34 pm    Post subject: Reply with quote
Most orgs have a stipulation that you cannot use oxygenated fuel. Not sure what the reasoning is. Many people shy away from it because it burns so fast you loose some of your jetting "cushion".
PostPosted: Wed Jan 30, 2013 4:29 am    Post subject: Reply with quote
From what I understood there were a couple of issues... Number one was safety of the tech guy, those additives are carcinogenic, and number two, the didgitron test doesn't do much with oxygenated fuel.
CR
scot smith
PostPosted: Wed Jan 30, 2013 4:46 am    Post subject: Reply with quote
If you do run it the extra oxygen will lean out your jetting. Therefore you would have to go to larger jets. Say your trying 10% oxygenated fuel you would want to increase your jetting by 10%.
PostPosted: Wed Jan 30, 2013 5:03 am    Post subject: Reply with quote
How does it effect the ignition curve?
CR
scot smith
PostPosted: Wed Jan 30, 2013 6:08 am    Post subject: Reply with quote
I was looking for fuel and ran across that jetting info on Sunoco's site. I would not have a clue on ignition curve.
PostPosted: Wed Jan 30, 2013 6:17 am    Post subject: Reply with quote
That's a VERY general rule, it doesn't always apply....
scot smith
PostPosted: Wed Jan 30, 2013 8:07 am    Post subject: Reply with quote
Sure, VERY general.
Ace Rossi
PostPosted: Thu Jan 31, 2013 3:38 am    Post subject: Reply with quote
Just use moth balls! One per 16 ozs of fuel and the sniffer wont detect it! You can run propylene oxide too but not sure about the sniffer test! Back in the day, I ran up to 8 oz's per gallon! Wink
DB time: 0.132308 (40.1%), total time:0.329955, queries:38
