SoCal Sprinters
RLV - SS
Leading Edge Motorsports
First Shifter... first alignmnent.. Need help
Sebastien Levesque
PostPosted: Mon Jan 28, 2013 12:34 pm    Post subject: First Shifter... first alignmnent.. Need help Reply with quote
Can I use a Sniper Alignment laser with a Shifter? It seems to me that the front disk brakes will be in the way.... :S
Where do you install it?
What is a good setup for a Tony kart Racer Shifter? Do you use a lot of toe-out?
Tyson Henry
PostPosted: Mon Jan 28, 2013 12:38 pm    Post subject: Reply with quote
You can use it with front brakes. Just move the hub out enough to allow clearance for the snipers. If the magnets aren't sticking too well through the aluminum brake/bearing carrier you can use some duct tape to hold the gauges on.
Not sure what others run but I like just a hair of toe out.
Randy Mckee
PostPosted: Mon Jan 28, 2013 1:05 pm    Post subject: Reply with quote
Tyson is right. I usually remove the hub assembly and put the sniper on the axle (old style tony front end) or directly on spindle (new style front end).
I usually run about 3mm toe out which equals approx zero toe with me in the kart. The amount if toe-in with you in the kart depends on your weight, how stiff and how wide you set the front-end. Since you're just starting, set it to 3mm total toe out and go run laps. 1.5mm per side = a dot and a half or just shy of the 1st line.
Hope that helps.
Randy
DB time: 0.126578 (41.25%), total time:0.306837, queries:38
