Leading Edge Motorsports
Another dumb question
Ace Rossi
PostPosted: Sun Jan 27, 2013 8:00 pm    Post subject: Another dumb question Reply with quote
Lower Radiator hose is routed in front of seat. Would it hurt to run it behind the seat and over the shift rod then slightly up and kind of over the left side of head and down thru the pipe straight onto the water pump nipple?
joseph hollinger
PostPosted: Sun Jan 27, 2013 9:16 pm    Post subject: Re: Another dumb question Reply with quote
Hurt? No. But sounds pretty complicated.
Matt Dixon
PostPosted: Sun Jan 27, 2013 9:31 pm    Post subject: Reply with quote
Hurt? Yes. If the hose came in contact with an 1100 degree pipe.
Matt Dixon
94y Energy Corse/Swedetech
Ace Rossi
PostPosted: Sun Jan 27, 2013 9:34 pm    Post subject: Reply with quote
Its nowhere near the pipe and it clears everything cleanly!
Ok let me ask this then. Where or how do you Honda guys run your hose if it runs behind the seat?
Sam Zavaglia
PostPosted: Mon Jan 28, 2013 4:14 am    Post subject: Reply with quote
Clears the pipe and shift rod by miles, tested for over 3 years on the oldest kart and as many as 12 karts that I have now put together and racing are all like this.
No more dumb questions, just look at the picture and figure it out.
BTW, it goes under the shift rod, not over it.
www.samzavaglia.com
Ace Rossi
PostPosted: Mon Jan 28, 2013 6:54 am    Post subject: Reply with quote
Looks good but I think I will go a different route!
I cant really runy hose the way you show above or
Below the shift rod without it rubbing. My J arm is in the UP position which has my shift rod is slightly curved!
Tyson Henry
PostPosted: Mon Jan 28, 2013 7:01 am    Post subject: Reply with quote
My hose comes over the top and in between the pipe. Works dandy.
Jeff DeMello
PostPosted: Mon Jan 28, 2013 11:25 am    Post subject: Reply with quote
I ran my hose like Sam's with no problems. Just make sure you secure it to the frame.
Jeff DeMello
Emmick F125 Pavesi
Cory Milne
PostPosted: Mon Jan 28, 2013 6:48 pm    Post subject: Reply with quote
i run my lower water hose up over the head of the motor alongside the upper hose then back down to the bottom of the radiator since it's a close system there is no problem
DB time: 0.112159 (36.92%), total time:0.303799, queries:38
