MaxSpeed - LB
Leading Edge Motorsports
Cleaning the inside of an RLV R4 Spec Honda pipe...?
Randy Mckee
PostPosted: Sat Jan 26, 2013 3:47 pm    Post subject: Reply with quote
Ken Schilling wrote:
Hey Fosso, even with Robert Marks, PP Mastro and Trevor McAllister moving up to S2 in PKC, S4 is still going to be stacked: McKee, Kidd, Hromada, Ruth, etc... Woo-hoo!!!
Yeah, S4 is always a good class. Sorry to say, but I don't think I'll make the 1st race. Ken, go kick some you-know-what with your freshly cleaned-out pipes. Not sure that came out right (oooh double pun).
Randy
darrell tunnell
PostPosted: Sat Jan 26, 2013 10:04 pm    Post subject: Reply with quote
Chris Fosso wrote:
hmm all good idea`s..
i have never done more then really soak mine....good info..
darrell, you going up to S-2 also? <smile!>
Chris at 52 I'll stick with the plus 30 . S4 is the best class , this yr will be very interesting and bad ass .
Jim Campeau
PostPosted: Sun Jan 27, 2013 6:55 am    Post subject: Reply with quote
Go to Home Depot or lowes and buy a piece of steel cable about 1/2 the length of your exhaust. Take the cable and unwrap the end- fray it and chuck the other end in you drill. Run the cable back and forth through exhaust from both sides. Use gloves, eye protection and be careful. Works great used it on my GP bikes for years.
Chris Fosso
PostPosted: Sun Jan 27, 2013 4:24 pm    Post subject: Reply with quote
ken , yea i know i was just talkin smack!.
all i can do is try...should be fun..
Arizona`s #1 MX Scene
www.GoMXracing.com
Chris Fosso
PostPosted: Mon Jan 28, 2013 6:53 pm    Post subject: Reply with quote
i wonder how hot you can get pipe... a friend has an oven for baking car heads...i could put pipe in.. and bake out inside,...
www.GoMXracing.com
Owen Rowell
PostPosted: Mon Jan 28, 2013 9:14 pm    Post subject: Reply with quote
the way i have always cleaned any pipe is in a caustic soda bath, it even removes R30 and M40 build up. "Drano".
cut the side out of a twenty litre industial drum, fill it with cold water, pour in half a kilogram of Drano, stir it with a stick till it desolve's, you'll feel the plastic drum get hot, put the pipe in leave it over night or a few days, take it out and hose it with high pressure cleaner,..works a treat,..the soda does all the work,
just don't get confused like a friend of mine and use hydrochloric acid and come back a few days later to an empty bin Laughing
joseph hollinger
PostPosted: Mon Jan 28, 2013 9:38 pm    Post subject: Reply with quote
What do you do with your superfund site when you're done?
Tyson Henry
PostPosted: Mon Jan 28, 2013 11:02 pm    Post subject: Reply with quote
I did the steel cable and drill drick mentioned above and it worked pretty well. Got a lot of carbon out. Wish I could get it all out though.
joseph hollinger
PostPosted: Mon Jan 28, 2013 11:07 pm    Post subject: Reply with quote
effing hot. I used to cook the leopard headers to cherry red (see pics above). No problem. It's mild steel, what's the issue?
Larry Andrews
PostPosted: Tue Jan 29, 2013 12:01 am    Post subject: Reply with quote
You neutralize the caustic with vinegar? Seems pretty easy...just throw in a splash of baking soda as an indicator and then add vinegar until the mix starts to bubble at pH 5. Everything goes down the drain after that and there isn't a septic or sewer system that can't handle that stuff.
All for being responsible and not into any form of being stupid. Arbitrarily saying no is just as silly as 'hey guys watch this'...
And, fwiw, caustic is the #1 most common industrial approach to cleaning burnt organics from steel without the downside of changing material properties significantly. Hi-temp guaranteed to have that effect... <shrug>
Owen Rowell
PostPosted: Tue Jan 29, 2013 12:41 am    Post subject: Reply with quote
Wink
joseph hollinger
PostPosted: Tue Jan 29, 2013 9:25 am    Post subject: Reply with quote
You think anyone does that?
Tyson Henry
PostPosted: Tue Jan 29, 2013 9:40 am    Post subject: Reply with quote
Curious, if people use this stuff to clean drains, why exactly does it need to be neutralized?
PostPosted: Tue Jan 29, 2013 2:33 pm    Post subject: Reply with quote
My thought exactly, Drano is designed to go down the drain, the only addition would be the rust and grease from the pipe.....
Kinda sound like what clogs a drain.....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Tyson Henry
PostPosted: Tue Jan 29, 2013 2:35 pm    Post subject: Reply with quote
CR
If anything, seems like it would be a good idea to throw it down the drain when you are done with it. Kill two birds with one stone.
Page 2 of 3
DB time: 0.179929 (41.49%), total time:0.43371, queries:38
