Acceleration - LB
Top Kart USA - SS
SCCA Enterprises - FB
Clunking from axle when spun?
Kyle Geddes
PostPosted: Fri Jan 25, 2013 9:17 am    Post subject: Clunking from axle when spun? Reply with quote
Folks - curious if anyone has ever seen (er.. heard) an axle that makes a clunking noise when spun?
With just the bare axle on my kart, no chain/tires - if i rotate it it makes a clunk, clunk, clunk - 3 times per revolution as near as i can tell. You can almost hear it more from the floor plan as the noise resonates from it, but it's clearly from the axles/bearing since they are the only thing rotating - can this be bad bearings?
Any thoughts on a fix? (besides buying new bearings - can these be re-lubed?).
thanks!
PostPosted: Fri Jan 25, 2013 9:36 am    Post subject: Reply with quote
Do you have a floating brake rotor on the axle or is that off too?
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Kyle Geddes
PostPosted: Fri Jan 25, 2013 10:12 am    Post subject: Reply with quote
I do yes.. that's a good idea, i'll check if its 'floating' around and clunking Wink
Ken Schilling
PostPosted: Fri Jan 25, 2013 11:22 am    Post subject: Reply with quote
If it's a shifter kart and has a reinforced axle, it may be the reinforcement that's worked itself loose. The reinforcement is basically a smaller axle a couple of inches long inside the axle and placed where the axle sprocket should be located. It's there to reinforce the axle due to the high loads from a shifter engine. I hope that makes sense...
Don't ask me how I know... Laughing
Ken Schilling
SKUSA Data Administrator
Randy Mckee
PostPosted: Fri Jan 25, 2013 12:58 pm    Post subject: Reply with quote
The others have made some good suggestions. I've also seen where the axle can slightly bind between the carriers and each rotation causes it to snap back to alignment making a knocking noise.
An easy test is to loosen one of the bearing carriers a bit so it's not locked to the frame. I usually loosen the center one. Turn axle and listen. If silent, then you'll want to carefully re-align the axle in all of the carriers.
Randy
Tim Doll
PostPosted: Fri Jan 25, 2013 8:07 pm    Post subject: Reply with quote
If you eliminate the other listed posibilities, it's almost certainly a bearing. Yes, you can re-lube them, but I'd recommend against it. If the bearing is 'clunking' - it means you've already damaged it. It's going to run hot, burn out the lube, and fail, with a good chance it'll damage the axle as well.
If you determine it's a bearing, replace it - they're not expensive (unless you get silly and get ceramic - a major waste of money) and you don't need to worry about it failing at a bad time.
Tim
Standard disclaimer - I'm FREE - No longer affiliated with any organization, I can say whatever I darn well please!.
Everett, Washington
Gary M Smith
PostPosted: Fri Jan 25, 2013 9:43 pm    Post subject: Reply with quote
Normally a bad bearing would give you clicking or a grinding noise, not a 3 clunks per rev. When my bearings need to be cleaned, I use a 2 pie pan method with mineral spirits, or paint thinner. I soaked the bearings in the first pie pan, spin the bearing repeatedly, blow compressed air into the bearing and repeat several times until the bearing seems free, then soak in the second pie pan with clean paint thinner and blow compressed air until clean. Lubricate with Dura Lube, and the bearings seem to be good as new. This process takes about 10 minutes per bearing and has worked for me for years.
Gary
#55 Honda CR-80
PostPosted: Wed Jan 30, 2013 11:18 pm    Post subject: Reply with quote
LOL, yeah that one got me too once.
Gif Cool
Yamaha KT100 Service Center
40 years karting experience
Keith Buffo
PostPosted: Thu Jan 31, 2013 10:14 am    Post subject: Reply with quote
Yeah, it's tough to tell exactly where those noises are coming from. Mike at CFMotorsports showed me a trick: Hold a screw driver to the caliper and each cassette and put your ear to the handle to help isolate the noise. More often than not, the noise is coming from the rotor.
Bearings do get dirty and can be cleaned. Once you have them in hand:
1.) Pop off the dust cover from the side away from the axle sleeve... use a very small/thin blade screw driver gently so you don't mangle the cover.
2.)Clean thoroughly. Do not allow them to move/spin much so you don't scratch up the internal surfaces. I've been lucky enough to have access to aqueous & mineral spirit washers... perhaps someone else can chime in with an at-home technique.
3.) Rinse with water. Then blow with compressed air until completely dry. If the blown out water is tinged, they're still dirty, so repeat 2 & 3 until clean. Again, do not allow them to move.
4.) Apply coat of spray grease. Allow to dry/set. Gently turn a little. Respray 3-5 times. At CFMotorsports we use Wurth HHS-2000.
This works great, and will save a relatively new set of bearings after a rain race or off-track excursion. None the less, I replace the bearings at least once a year. Hope that's helpful.
Keith Buffo
http://BondedTransmission.com
http://CFMotorsports.com
http://DRT-Racing.com
http://OhCopyboy.com
http://www.NHKA.net
bob prinzo
PostPosted: Sat Feb 09, 2013 8:56 pm    Post subject: Reply with quote
its thebrake rotor
GP9/leopard no.47
wildkart/HPV1 no.10
Lawrence Doty
PostPosted: Sat Feb 09, 2013 10:37 pm    Post subject: Reply with quote
Hub keys
Evan Fraser
PostPosted: Wed Mar 20, 2013 10:24 am    Post subject: Reply with quote
I once had a seat strut and a set screw on the right bearing bumping into each other just enough to make a slight bump noise and slow the axle slightly. Wound up moving the seat strut to the other side of the bearing carrier.
DB time: 0.321617 (70.53%), total time:0.456027, queries:38
