Acceleration - LB
MG Tires - SS
Grid distance
Britt Robinson
PostPosted: Thu Jan 24, 2013 8:39 am    Post subject: Grid distance Reply with quote
At my local track our grid is painted so that the distance between, say P1 and P3, ends up being about 3' tail to nose. Because of a few botched starts, some by me Rolling Eyes , the club decided to visually grid the karts farther apart instead of using the painted lines for increased safety. My question is; Do any of the sanctioning bodies have some kind of standard distance for the grid?
I am a precisional instrument of speed and aeromatics. - Mater
Randy Mckee
PostPosted: Thu Jan 24, 2013 2:42 pm    Post subject: Reply with quote
I don't think there's a standard and it varies quite a lot from race to race. A few factors that might influence the lineup is number of competitors, track design, and of course what you mentioned, the perspective of the officials.
Checkout how tight this line-up was at the PKC 2010 north-south shootout.
http://vimeo.com/15064187
That is the tightest lineup I've ever seen, and surely a recipe for disaster. They had a huge number of entries and the track design leading to the start/finish is curved, so a tough situation. Luckily, most of those drivers continued.
My take: Stagger the grid and probably 3 to 4 kart lengths between rows. That way if both karts in a row stall, there's an easier route around them. Here's an example at the same track, same series but fewer entries:
http://www.youtube.com/watch?v=x1fP4Vs8erc
Randy
Britt Robinson
PostPosted: Thu Jan 24, 2013 3:57 pm    Post subject: Reply with quote
I swear our starts aren't too far from that example, Randy! If somebody kills it there is absolutely nowhere to go.
Roger Miller
Site Admin
PostPosted: Thu Jan 24, 2013 5:56 pm    Post subject: Reply with quote
As we traveled to different tracks and needed our own grid markings, I built a simple thing out of sprinkler pipe (the white stuff, I always forget if that is PVC or ABS, or whatever) and we used a staggered grid, so pole was ahead of P2 and P2 was ahead of P3, similar to F1.
Then, the distance between nose of P1 and nose of P3 was setup to be 10 foot plus a couple of inches. In other words, used a 10' length of pipe, cut it in the middle for T connection, and then put 2' pieces on 90 degree connectors at each end and on the T in the middle.
P1 |________________________| P3
.........................| P2
(Sorry about the periods in there, the forum suppresses leading spaces so it wasn't showing up correctly with out them)
Sorta like that - 10' long and 4' across. Inside front tire on the mark, so P1 puts left front on the mark, P2 puts right front on the mark, and P3 puts left front on the mark.
Then it was a simple, drag it down the track, line up P1 end on P3 mark, mark P4 and P5, repeat.......
And the whole thing broke down to the pieces and was easily stored in the trailer.
We stopped doing standing starts and went to all rolling starts on the track (still do wall starts, but that is a whole different thing) but if we would have continued to do this, I would have added holes in the fittings to be able to put pins in to lock in the side pieces and the middle connection.
Roger Miller
NCK President
www.nckroadracing.com
Jim McMahon
PostPosted: Fri Jan 25, 2013 3:01 pm    Post subject: Reply with quote
I believe there are stipulations in the FIA\CIK rulebook but I'll be darned if I can find them!
chuck hurlbert
PostPosted: Sun Jan 27, 2013 3:39 pm    Post subject: Reply with quote
this is for club racing so the rule book doesnt really matter. our club just lets us do what we want pretty much. we qualify and half the time we almost pick where we want to start b/c the fast guys like to start last to pass all us fat slow guys (me included) Very Happy
britt, if we keep inverting the field like last year i can see your point because bunching all noobs up front can be a dangerous situation.
Shifter newb
Tim Salvino
PostPosted: Sun Jan 27, 2013 7:11 pm    Post subject: Reply with quote
That is true, but the FIA regs will at least let you know how most people do it. All "FIA/CIK Legal" tracks will have the grid laid out as told in the rulebook, which should be a solid starting point for your club.
Mike Beeny
PostPosted: Fri Feb 01, 2013 12:04 pm    Post subject: Grid Reply with quote
Its also a good idea to set the grid markers closer to the center of the track as opposed to being further out toward the edge of the track. I would guess having a maximum of 3ft or so on a 29ft track is good.
The reason for this is it allows you an opportunity to move to the outside edge of the track in the event someone is low off the line. When the grid markers are too far apart everyone has a tendency to move towards the center of the track and ultimately have no place to go.
Mike Beeny
www.msquaredkarting.com
www.used-karts.com
Britt Robinson
PostPosted: Fri Feb 01, 2013 4:52 pm    Post subject: Reply with quote
You hit our grid markings almost perfectly, Roger. I had some time today and took a tape measure out to the track. It measured exactly 10' nose to nose. I'm still curious if there is a standard out there somewhere. We are an IKF track but couldn't find anything in my old rule books.
DB time: 0.118757 (40.24%), total time:0.295152, queries:38
