Margay Racing
Ribtect - SS (non-flash)
Leading Edge Motorsports
Different angled carb boots?
Scott Boito
PostPosted: Wed Jan 23, 2013 6:23 pm    Post subject: Different angled carb boots? Reply with quote
Hi all,
I'm wondering if there are different angles for the carb boot for folks running angled mounts? We only have a 7 degree mount, but I'd like to get the carb as close to level as possible to avoid any float problems.
If there aren't different angled boots, do I just adjust the float level to compensate?
Thanks, Scott
KM #68 - Haase/Honda kart
BetterOffRacing
Member of the SCCA KAC
Jeff Stamper
PostPosted: Wed Jan 23, 2013 9:45 pm    Post subject: Reply with quote
What engine are you running ? If its a 206, just use the 7. I would leave the float alone. The Animal is intended to be run at 7 degrees. If its an Animal, then you can get different boot angles
Racing is a State of Mind ! ... A very nice state to be in !
Scott Boito
PostPosted: Thu Jan 24, 2013 6:27 am    Post subject: Reply with quote
It's a World Formula and I've been informed that there is only one standard boot. So I guess adjusting the float level is the way to go.
Thanks, Scott
BetterOffRacing
Dean Graves
PostPosted: Thu Jan 24, 2013 11:05 am    Post subject: Reply with quote
7 degree will work just fine with the W/F. Seen them run from zero degrees to fifteen degree mounts.
George Vorrilas
PostPosted: Sun Feb 24, 2013 9:36 am    Post subject: WF carb boot Reply with quote
We run a number WF packages on 2 stroke sprint chassis. mounts vary between 7 and 15 degrees depending on the speccific chassis. To date we have not exxperienced any issues or performance losses due to the mount \ float angle. I agreee that at first glance it looks to be problematic but i think you will see that it works fine.
George V.
ApexKartSports
www.apexkart.com
9788-479-77974
Ron Carello
PostPosted: Mon Feb 25, 2013 1:56 pm    Post subject: Re: Different angled carb boots? Reply with quote
Scott Boito wrote:
Hi all,
Thanks, Scott
I have a blueprinted WF engine/carb package, and a completely stock WF engine/carb package. B&S states to mount them as level as possible. However, I have always run a 7 degree mount and have never had to adjust the float level to fit the angle of the mount. Install the 7 degree mount and have fun.
Bernie Lacotta
PostPosted: Mon Feb 25, 2013 6:03 pm    Post subject: Re: Different angled carb boots? Reply with quote
Ron Carello wrote:
Scott Boito wrote:
Hi all,
Thanks, Scott
They also run fine on 15 deg. mounts. If you have any problem address it then,until then,as said before,have fun!
I breathe ,therefore,I race
DB time: 0.174029 (40.87%), total time:0.425765, queries:38
