2D2W - LB
K1 Speed - SS
1998 cr125 front motor mount bolt size??
Greg Narvas
PostPosted: Mon Jan 21, 2013 6:46 pm    Post subject: 1998 cr125 front motor mount bolt size?? Reply with quote
I have a stock 98 cr125 motor with a steel psr motor mount. The motor mount uses m10 bolts. These bolts do not fit through the front mounting location of the case. From reading older posts, it seems that in 99 they used the larger m10 bolt rather than the m8 bolt from 1998 and older motors. I've read that I should use a 7/16 dill bit to drill the case out but 7/16 is closer to being 11.11mm. Is that too much slop for an m10 bolt or is that ok? I've read of people on here using a 3/8" drill bit with 3/8 bolt but I would feel better using the supplied m10 bolt.
Second, I just rebuilt my motor so it's fully assembled. Is it ok to drill with a good quality hand drill or would it be wise to do it while the cases are separated?
PostPosted: Mon Jan 21, 2013 8:01 pm    Post subject: Reply with quote
The PSR mount came either with a 5/16" bolt prior to the 99 motor's or 3/8" after the 99 motors, they never used a 10mm bolt that I knew of. Somebody might have drilled the mount for a 10mm if it has one.
You can drill the early cases out to 3/8", it's a little easier if the cases are dissembled, but you can do it after as well. Drill from either side, should be ok...
If it's a 10mm bolt, I would not drill it to 7/16", 13/32's is closer, or buy a 10mm bit.
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Greg Lindahl
PostPosted: Tue Jan 22, 2013 11:13 am    Post subject: Reply with quote
From experience, use the correct bit size (10mm, etc.) and drill slowly and carefully for best results.
Greg Narvas
PostPosted: Tue Jan 22, 2013 11:28 am    Post subject: Reply with quote
I ended up following CR's advice. I didn't realize that that PSR front mount bolt was actually 3/8". So I ended up getting a 3/8" drill bit and slowly drilled out the front case and everything fits nice and snug. Thanks again!
PostPosted: Tue Jan 22, 2013 2:42 pm    Post subject: Reply with quote
Measure twice, drill once Very Happy
CR
DB time: 0.489484 (82.6%), total time:0.59257, queries:38
