Sam Zavaglia
Joined: 23 Nov 2004 Posts: 1189 Location: Australia, Sydney,
Posted: Thu Jan 17, 2013 4:12 pm Post subject: Gear Oil for CR125 |
Just to start another comedy of information on these forums, I use Castrol MTX which is very cost effective in Australia. Not sure if this is available in the USA.
http://www.castrolmoto.com/au/our_oils_new/mtx_gear_oil.php
I only change my gear oil at least 1-2 years apart.
Anyway, I put Castrol MTX into my very first CR125 kart engine. Over six months later, the Redline rep said...."mate you gotta try this blah blah blah....and more horsepower.
So since there is a drop in HP through the gearbox and I got the stuff for free for testing and feedback, thought I'd test it proper. I went to a "rolling road" dynojet dyno with my gearbox still with original Castrol MTX and got a read out. Drained the gear oil while still warm and dropped this exact Redline stuff in.
http://www.redlineoil.com/product.aspx?pid=112&pcid=26
The next dyno read out was exactly the same .......could not spot a single difference......what a load of crap I said to myself.
This Redline stuff now stayed in the engine for a further 2 years....never changed. So after the engine was 3000miles and nearly 3 years old, I've had Castrol MTX for over six months (at least 6 race meetings) and then 2 years without a change on the Redline stuff, I decided time to change the crankshaft as preventative maintenance.
After opening the crankcases, the gears/dogs all looked virtually perfect, the shift forks like brand new.
I also did another engine rebuild with over 2 years on Castrol MTX never changed, very similar results, maybe not quite as perfect as Redline but still very remarkable and worthwhile staying with Castrol MTX.
Both engines, no magnetic drain plug, no notable bits of metal in the gear oil.
This is the engine with over 2 years on a single fill of Redline, over 2000miles on that gear oil, I know you can't see the dogs but imagine it looks as good as the rest of it.
Has everyone else got the same results? I imagine so since I do not read any bitchin about CR125 gearboxs on here.
Has anyone got notable differences between different brands of gear oil that are specific to motorcycle/wet clutch use? _________________ www.samzavaglia.com |
Jeff DeMello
Joined: 13 Sep 2002 Posts: 2213 Location: United States, Pittsburgh Pa,
Posted: Thu Jan 17, 2013 4:41 pm Post subject: |
I only used Mobil 1 synthetic oil with no gear box problems. I would change after every season of racing.. _________________ Jeff DeMello
Emmick F125 Pavesi |
Ken Schilling
Posted: Thu Jan 17, 2013 5:56 pm Post subject: |
Wow, you guys change your transmission oil very infrequently compared to me... I change mine every race and use TransOil 2T 10W30. The CR-125 trannys are considered to be bulletproof and I do it this frequently as a relatively inexpensive preventative measure as well as trying to extend the life as much as possible. I'm on a shoestring racing budget and don't want to open the bottom end unless absolutely necessary.
http://www.corseracing.com/Motul-TransOil-Petroleum-Gear-Oil-1L-One-Liter-Bottle-10W30-p3568.html?gclid=CMX42YLY8LQCFayPPAodq2QATA _________________ Ken Schilling
SKUSA Data Administrator
The opinions I express are mine alone and do not reflect those of any organization of which I am a member. |
Mike Goebel
Joined: 28 Jul 2001 Posts: 5766 Location: United States, California, Winnetka
Posted: Thu Jan 17, 2013 6:35 pm Post subject: |
Sam you have to change it more offten It "Will" never last as long as it already did!
mfg Technology Centre
Sam Zavaglia
Posted: Thu Jan 17, 2013 6:58 pm Post subject: |
| Ken Schilling wrote: | | Wow, you guys change your transmission oil very infrequently compared to me... I change mine every race and use TransOil 2T 10W30. The CR-125 trannys are considered to be bulletproof and I do it this frequently as a relatively inexpensive preventative measure as well as trying to extend the life as much as possible. |
OK, so instead of changing your gear oil every race meeting, you could save $15 towards another head gasket.  _________________ www.samzavaglia.com |
Jim McMahon
Joined: 07 Apr 2007 Posts: 2685 Location: United States, St. Paul,
marc-andre hubert
Posted: Thu Jan 17, 2013 7:16 pm Post subject: |
| i use honda racing oil 75w90 shift great and offers great protection |
Sam Zavaglia
Posted: Thu Jan 17, 2013 7:24 pm Post subject: |
| Jim McMahon wrote: | | Do you still have the oil Sam? You should send it off for analysis. |
Funny that, I only had 500ml left over of new Redline and needed 650ml to complete the rebuild. I took 150ml from the 2 year old gear oil and blended that with 500ml off the new stuff.
I'll soon have head gaskets coming out of my ass at this rate of budgeting.
So yes Jim, I still have 500ml of the 2 year old Redline here yet to be disposed......but Redline is not based in Australia, just small importer, so who would care in Australia for an analysis? _________________ www.samzavaglia.com |
Jim McMahon
Posted: Thu Jan 17, 2013 8:58 pm Post subject: |
| Sam Zavaglia wrote: | | So yes Jim, I still have 500ml of the 2 year old Redline here yet to be disposed......but Redline is not based in Australia, just small importer, so who would care in Australia for an analysis? |
I was thinking more from the standpoint of having data on the condition of the oil after 3000 miles. Not necessarily that oil, but just in gernal. How much observed viscosity, how much viscosity modifier is left, metal particulate type and content. Basically scientific evidence on whether changing the oil as often as some do is in anyway worthwhile. _________________ Live in the midwest and have a TaG, Shifter, KPV, KT100, Animal\LO206, enduro or superkart?
Michael Taksa
Joined: 25 Jul 2001 Posts: 1401 Location: United States, Massachusetts, Boston
Posted: Fri Jan 18, 2013 10:15 am Post subject: |
| The consensus is that the tranny on that motor is bulletproof, so it will run on whatever you put in it. I use mobil1 syntetic 5W30, used 10W30 in the past, but now my car wants 5W30, so my kart gets the same oil I already have. |
