Margay Racing
KG Plastics - FB
2 New Superkarts, Anderson GasGas, Nemisis CR, PICS
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Kart Packages
James Carmen
PostPosted: Wed Jan 16, 2013 8:55 am    Post subject: 2 New Superkarts, Anderson GasGas, Nemisis CR, PICS Reply with quote
New 2008 Anderson Superkart with Gas Gas 250. Turn key race ready kart just broken in, no races. Two color blue and white gel coat from Anderson, rack and pinion steering, rear diffuser, XL Anderson seat, billet rear axle water pump, silicone water lines, MyChron 4 with GPS. 2 sets of wheels and tires, complete set of Anderson rear gears. 250 GasGas factory prepped by Manfred, wide ratio transmission, 40mm Mikuni carb, hydraulic clutch.
Price $13,500 Kart is located in Oklahoma City.
Contact James at: jc_speedworks@hotmail.com
photos available here:
http://s189.beta.photobucket.com/user/jc_speedworks/library/Anderson%20Gas%20Gas?track=share_email_album_view_click
New Nemesis Superkart with 2004 Honda CR250. Completed the built in Aug. of 2009. These karts are built second to none. Kelgate brakes, spindles, hubs, axle and bearing cassetts. Upgraded BRC front brake discs. Carbon fiber dash with brake bias and MyChron 4 E-box with H2O and EGT temp, speedometer, RPM and track mapping, mounted on the back. 40mm rear axle with complete set of quick change rear gears. Carbon fiber rear wing and up rights, radiator shroud with scoop and seat. Full length carbon belly pan with rear diffuser. Big radiator mounted at the rear. All the hardware on the chassis is titanium or aluminum. Three sets of new wheels with Bridgestone Superkart tires. 2004 Honda CR250 motor modified by Reynard Modifications. 2005 crankshaft, no sheet metal, solid crank halves. Transmission and any rotating gear has had REM treatment. Complete Hinson clutch assembly, inner and outer baskets, pressure plates, fibers, metals and springs. V-Force 2 reed cage with custom CNC machined intake manifold using a RS125 isolator. New 38mm Keihin carb. No pump-around, modified needle and seat. Matrix pipe, custom coned tail section with RLV titanium silencer. This kart has never been on the track, only test driven on the road around the shop. Chassis new was $12,900 plus engine and accessories.
Price $12,500 Kart is located in Oklahoma City.
Contact James at jc_speedworks@hotmail.com
http://s189.beta.photobucket.com/user/jc_speedworks/library/Nemisis%20CR250?track=share_email_album_view_click
James Carmen
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Kart Packages All times are GMT - 8 Hours
DB time: 0.074469999999999 (44.69%), total time:0.166633, queries:38
