Italian Motors - LB
Russell Karting - SS
Catch can for carb hoses
Goto page 1, 2  Next
Todd Renaud
PostPosted: Tue Jan 15, 2013 10:03 am    Post subject: Catch can for carb hoses Reply with quote
Just got a shifter and going through it. I'd like to have these hoses go into a catch-can of some sort. Anyone have a pic of how they do this?
TIA...Todd
Shifter Kart as Delivered by Speedracer92, on Flickr
Steve Buckner
PostPosted: Tue Jan 15, 2013 10:20 am    Post subject: carb Reply with quote
Run them up the carb as you see in photo. Cut a small notch at the very top of both hoses to vent. The yellow markers are for water hoses.
Jimmy McNeil
PostPosted: Tue Jan 15, 2013 1:17 pm    Post subject: Reply with quote
Routing the vent lines up will keep it from making a mess and will run ok but is not optimal. The carb was designed to run the vent lines down.
Steve Buckner
PostPosted: Tue Jan 15, 2013 2:46 pm    Post subject: carb Reply with quote
He can fix it for $400.00 LMAO.
Jimmy McNeil
PostPosted: Tue Jan 15, 2013 2:54 pm    Post subject: Reply with quote
Like I said, it will run ok with the lines up like you suggested.
If he wants to run the vent lines down as they were intended, he can run them into a catch can.
Or yes Steve, he can do what almost all the top pro's do and buy a fuel system that solves the problem
Todd Renaud
PostPosted: Tue Jan 15, 2013 3:40 pm    Post subject: Reply with quote
Thanks. Just got the kart so not at the "pro level" yet and would rather make do with the setup I have now. Catch can was what I was thinking - just wanted to see how people did it if they did so that way...
Jimmy McNeil
PostPosted: Tue Jan 15, 2013 3:47 pm    Post subject: Reply with quote
If your just starting out and not concerned about getting that last .01 doing what Steve suggested will work fine.
Jason Berry
Advertiser
Advertiser
PostPosted: Tue Jan 15, 2013 6:36 pm    Post subject: Reply with quote
Todd,
Make sure you do not place the black vent hose coming out of the case into the same catch bottle.
It can syphon the over flow back into the transmission/clutch area.
www.shopswedetech.com
www.swedetechracing.com
www.swedetechracing.com/news-events-blog/
www.facebook.com/Swedetech
Jason Berry
Advertiser
Advertiser
PostPosted: Tue Jan 15, 2013 6:37 pm    Post subject: Re: carb Reply with quote
plus shipping!
Ryon Beachner
Advertiser
Advertiser
PostPosted: Wed Jan 16, 2013 12:07 am    Post subject: Re: carb Reply with quote
plus shipping!
Don't forget sales tax if you're in California!
2Wild Karting
www.2wildkarting.com
Shop: (949) 206-9906
Todd Kageals
PostPosted: Thu Jan 24, 2013 2:15 pm    Post subject: Reply with quote
Jason Berry wrote:
Todd,
Oh snap!! I just finished routing all my vent lines to a catch can and put the carb overflow and the crankcase vent in the same bottle! Maybe I'll just shorten the black hose so it will not be immersed in the fuel overflow.
Todd Renaud
PostPosted: Thu Jan 24, 2013 2:19 pm    Post subject: Reply with quote
Todd - can you place a pic so can see how you did this?
Sam Zavaglia
PostPosted: Thu Jan 24, 2013 2:30 pm    Post subject: Reply with quote
When you want to empty it, you simply lift up and unscrew the bottom part of the bottle, no need to pull the lines out. Make sure you have a extra hole in the top so that the bottle/lines can breathe.
www.samzavaglia.com
Todd Kageals
PostPosted: Fri Jan 25, 2013 11:41 am    Post subject: Reply with quote
That's how I did it.
Jimmy McNeil
PostPosted: Fri Jan 25, 2013 4:17 pm    Post subject: Reply with quote
Todd, have you driven the kart with that catch can? I was wondering how many laps you could go before it was full.
The reason I ask, a few years ago I had a similar set up, it would fill up in less than 12 laps. After a 20 lap main, my kart was dripping with pre-mix and my fellow competitors were not happy.
Im wondering if thats the norm or if mine was unusually bad.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.145694 (39.51%), total time:0.368763, queries:38
