SKUSA (non-flash) - LB
Streeter - SS
Tired of blown head gaskets and ruined pistons?
Andre Eriksen
PostPosted: Tue Jan 15, 2013 4:38 pm    Post subject: Reply with quote
Thanks Ken,
As I wrote earlier - the fuel/oil is the common denominator among all drivers. I'm a metric guy so I have to go back and look at the Ratio Rite to see, but I am fairly sure that almost everyone, myself included, are using more oil than specified...
We did change to another brand over the season though as well as they changed to 110 octane. We are mandated to run Redline Oil.
2012 Formula Car Challenge Vice Champion (Pro Formula Mazda)
2011 Rotax DD2 Masters National Points Champion
2011 NorCal DD2 Masters Vice Champion
2010 NorCal Rotax Masters Champion
www.viking-racing.com
http://www.facebook.com/VikingRacing
Ken Schilling
PostPosted: Tue Jan 15, 2013 4:41 pm    Post subject: Reply with quote
Andre Eriksen wrote:
...but I am fairly sure that almost everyone, myself included, are using more oil than specified...
You're welcome Andre.
I think that maybe we have found at least part of the problem...
Use no more than 6 ozs of oil per gallon.
Ken Schilling
SKUSA Data Administrator
Andre Eriksen
PostPosted: Tue Jan 15, 2013 4:49 pm    Post subject: Reply with quote
Well yes let's see... I did run the specified amount of oil at some point - that resulted in two stuck and ruined cylinders. I was not lean in either case, just bad lubrication... Piston looked great (on the top) and was wet on top as well.
Chris Hegar
PostPosted: Tue Jan 15, 2013 5:08 pm    Post subject: Reply with quote
Fire your tuner. Laughing 110 won't hurt it should only help eliminate det and that oil should be fine at that ratio. If you all had damage than you all had to lean of a setup for whatever air was being ran in that we have no record of. Bump up to a richer needle, up the main, up the pilot then back off the timing if she blows again. If it's stock 99 it should run for 1000 years straight. Wink Remember it's just a pump, leaning on any pump can kill it and what you ran last week is not always what you can run this week.
www.Hegar4.com
Andre Eriksen
PostPosted: Tue Jan 15, 2013 5:12 pm    Post subject: Reply with quote
Here we go again... I don't even want to comment.
Chris Hegar
PostPosted: Tue Jan 15, 2013 5:17 pm    Post subject: Reply with quote
Take it to Swedetech.
www.Hegar4.com
Jeff DeMello
PostPosted: Tue Jan 15, 2013 5:18 pm    Post subject: Reply with quote
Why is it I have received several PM's this afternoon with people who are 100% familiar with this problem they just don't want to get in to the Honda VS something else discussion...?
This thread has nothing to do with Honda vs ???????????
I'm done
Jeff DeMello
Emmick F125 Pavesi
Andre Eriksen
PostPosted: Tue Jan 15, 2013 5:33 pm    Post subject: Reply with quote
I don't know what you call it when people leave one brand because of problems and move to another...
Chris Hegar
PostPosted: Tue Jan 15, 2013 5:43 pm    Post subject: Reply with quote
What's a vice champion?
www.Hegar4.com
joseph hollinger
PostPosted: Tue Jan 15, 2013 5:49 pm    Post subject: Reply with quote
It means that you're the Don Johnson of Rotax.
Andre Eriksen
PostPosted: Tue Jan 15, 2013 5:53 pm    Post subject: Reply with quote
vice
/vīs/
Noun
Immoral or wicked behavior.
Preposition
As a substitute for: "the letter was drafted by David Hunt, vice Bevin who was ill".
Combining form
Acting as deputy or substitute for; next in rank: "vice regent"; "vice-consul".
Synonyms
noun. defect - vise - fault
preposition. instead of - in place of - in lieu of - for
I will be happy to assist you with any other language challenge you have!
Jason Berry
Advertiser
Advertiser
PostPosted: Tue Jan 15, 2013 6:19 pm    Post subject: Reply with quote
Andre,
I notice the head you show machined has two outlets and the one on the engine has one outlet.
What is the difference between the two?
Does the O-ring head take into account the water flow and restrictions that the was engineered by Honda when using a stock head gasket?
I'm also very curious about the design of the outer o ring groove. How will this affect machining costs vs a simply round groove?
My vote is to allow machining, it would be an extra way to make a buck on a Stock Moto class. Twisted Evil
--- Steve B, post your next comment here Arrow
_______________________
Chris,
Corrected altitude at Sonoma last weekend was - 1000 ft to 500 ft, depending on the time of day.
Fuel system used by Pro Stock Honda Champion and Vice Champion is the GFS.
Fuel system used by the Master Stock Honda champion is also the GFS. Same engine builder for all three.
Hope this information helps with your diagnosis.
www.shopswedetech.com
www.swedetechracing.com
www.swedetechracing.com/news-events-blog/
www.facebook.com/Swedetech
Chris Hegar
PostPosted: Tue Jan 15, 2013 6:30 pm    Post subject: Reply with quote
In "vice" I was wondering if you were a navigator or "co" pilot with someone much like rally has. It's been wonderful speaking with you.
www.Hegar4.com
PostPosted: Tue Jan 15, 2013 6:32 pm    Post subject: Reply with quote
Hey Jason, stop throwing facts around, wadda trying to do!!!! Very Happy
Andre, take it Swedetech....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Sam Zavaglia
PostPosted: Tue Jan 15, 2013 8:19 pm    Post subject: Reply with quote
Not intended to offend, but would "vice" suggest the first loser or there is someone better?
eg,
Vice President v President
Vice Captain v Captain
Vice Champion v Champion
Back to oil ratio, if you make a ratio of more oil in your mix, would that suggest there is less fuel in that mix.....meaning a leaner fuel to air ratio using the same jetting given all other conditions are the same?
Just saying, there is still a balance to consider there with oil ratio.
Anyway, take it to Swedetech, can't say I've heard bad things about the way their engines run.
www.samzavaglia.com
Page 3 of 6
DB time: 0.095249000000003 (43.45%), total time:0.219207, queries:38
