IKF Region 7 - LB
Leading Edge Motorsports
CR125 Carburetor Problems
Goto page Previous  1, 2, 3, 4, 5
Jeff DeMello
PostPosted: Sat Jan 19, 2013 5:49 pm    Post subject: Reply with quote
Todd it's good to see you found your problem..
Jeff DeMello
Emmick F125 Pavesi
Sam Zavaglia
PostPosted: Sat Jan 19, 2013 7:58 pm    Post subject: Reply with quote
Jeff DeMello wrote:
adjust your float level
Sam Zavaglia wrote:
Now lower the float a little, if you set to the standard spec it is pretty high almost to the overflow level anyway
Jeff,
Was it your doing or my doing? Laughing
Glad it worked out for you Todd, at least you now have a better understanding. Wink
www.samzavaglia.com
Jeff DeMello
PostPosted: Sat Jan 19, 2013 8:44 pm    Post subject: Reply with quote
Sam since my fix was the very first one posted I win Laughing
Jeff DeMello
Emmick F125 Pavesi
Steve Buckner
PostPosted: Sat Jan 19, 2013 9:49 pm    Post subject: Reply with quote
This is what we should be doing, helping fellow karters with there problems not trying to spend there money for them. Wink
To the Avengers, DEEEEEEEZ nuts.
Todd Kageals
PostPosted: Sun Jan 20, 2013 7:43 pm    Post subject: Reply with quote
Steve...Jeff....Sam,
Just wanted to let you know that I was not ignoring your advice on the floats. I was trying "solutions" one at a time to see if I could isolate the problem. The first thing I tried was moving the pump and that did absolutely nothing. The second thing I tried was adjusting the floats which seems to have done the trick. I was ready to try a bypass line as setup in a diagram Steve sent me but fortunately I did not even have to do that. The kart is ready to run....I can't wait to get it out and give it a good test. I'll be heading down to MMX as soon as it warms up enough! Thanks again for the help.
Todd
Mike Goebel
PostPosted: Sat Feb 02, 2013 4:22 pm    Post subject: Reply with quote
Chris Laird wrote:
Here's something else you might try.
http://www.shopswedetech.com/mobile/default.aspx#P327
A bunch of people have already spent 100's of hours and thousands of dollars coming up with "the" solution to your problem. Laughing
I still think the Delorto fuel pump works pretty good. What do you think after today??
Mike G.
Closet KZ Lover!!!
mfg Technology Centre
Page 5 of 5
DB time: 0.246849 (51.63%), total time:0.478087, queries:38
