Leading Edge Motorsports
neck support?
Goto page 1, 2  Next
Justin Mitchell
PostPosted: Sun Jan 13, 2013 9:24 pm    Post subject: neck support? Reply with quote
So... I autocross a shifter kart (mod moto), but have been considering doing some sprint races. Today I took the kart to Mooresville Motorplex. After a couple of short sessions, I became unable to keep my head up straight around long/fast turns. It's bad enough that I could barely see where I was going around some turns. I was driving on MG Greens. I use a foam donut from K1 racing.
#1 Is there any better neck support that will make a significant difference with this?
#2 The tires I was using today are stickier than most. Mooresville users the Hoosier R60A as the spec tire for their leagues. Do you think I'll have this problem with a harder tire, such as these? Was I just driving on way too much tire?
Anyways, thanks in advance Smile
Last edited by Justin Mitchell on Sun Jan 13, 2013 9:28 pm, edited 2 times in total
joseph hollinger
PostPosted: Sun Jan 13, 2013 9:26 pm    Post subject: Re: neck support? Reply with quote
Not really. The best thing you can do is either drive a lot more or do exercises to strengthen your neck.
PostPosted: Mon Jan 14, 2013 7:19 am    Post subject: Reply with quote
As Hollinger said, doing some neck exercises will help more than anything.
There are some pretty thick, huge, uncomfortable foam neck braces you can get but they don't allow you to move your head around much and they make you look like a noob Wink
T.J. Koyen
www.oktanevisual.com
Exprit/Leopard
Tim Reed
PostPosted: Mon Jan 14, 2013 7:30 am    Post subject: Reply with quote
Justin - what kind of helmet are you wearing? Maybe look into a lighter helmet, too.
Ken Schilling
PostPosted: Mon Jan 14, 2013 7:55 am    Post subject: Reply with quote
I've found that thicker neck braces can actually work against you by not allowing you to tilt your head into the corner to counteract the G forces. Your helmet may also not have a "cut out" to clear your collarbone when you tilt your head. Helmet weight is also crucial, get the lightest helmet you can.
Ken Schilling
SKUSA Data Administrator
Justin Mitchell
PostPosted: Mon Jan 14, 2013 8:28 am    Post subject: Reply with quote
I have an Arai GP-6s that I use for road racing. As far as SA-rated helmets go, it's relatively light, but it's still not the lightest thing out there. I'll have to look into karting helmets and see how they compare in weight.
Jeff DeMello
PostPosted: Mon Jan 14, 2013 8:50 am    Post subject: Reply with quote
Justin, keep doing laps in your kart.. Your neck mussels will get stronger.
Jeff DeMello
Emmick F125 Pavesi
Marshall Martin
PostPosted: Mon Jan 14, 2013 6:27 pm    Post subject: Reply with quote
I went thru several years of not being able to complete more than 5 laps because my neck would give out and the pain was unbearable. I finally went thru some physical therapy for a should and talked to the therapist about my neck. She gave me some things to do but still no help. I went looking and found the following exercises;
http://www.youtube.com/watch?v=98NYmIRkHf0&feature=relmfu
I modified it a bit using a flat 3lb weight from Dick's Sporting Goods and laying flat on the floor with my legs up. I started with 5 reps each (back, right side, left side) and 3 sets. Within 2 weeks I was up to 15 reps each and 3 sets.
After 2 weeks I made a practice run of 20 laps and completed a 12 lap pre-final and 16 lap final. I was able to do a 28 lap final about 2 months later.
These were all at the South Bend track which is .6 mile tight track with very little resting time and high G Force.
I now do 4 sets of 15 reps each at least 5 times a week.
Simple cheap and effective. I think the weight cost me about $8.
Marshall Martin
LSR Motorsports
www.lsrmotorsports.com
marshall@lsrmotorsports.com
Justin Mitchell
PostPosted: Mon Jan 14, 2013 6:55 pm    Post subject: Reply with quote
Nice! Thanks Marshall. I'll definitely try that exercise and report back!
joseph hollinger
PostPosted: Mon Jan 14, 2013 8:25 pm    Post subject: Reply with quote
You're helmet is a 3 pound weight. Something to do when you are watching TV--with your helmet on. Nothing weird about that.
Gerry MacNutt
PostPosted: Mon Jan 14, 2013 10:33 pm    Post subject: Reply with quote
Arai GP-6s = boat anchor
Justin Mitchell
PostPosted: Mon Jan 14, 2013 10:47 pm    Post subject: Reply with quote
::sigh:: Just spent $1000 on a helmet and I gotta get another.
What's a good, lightweight kart helmet?
joseph hollinger
PostPosted: Mon Jan 14, 2013 10:55 pm    Post subject: Reply with quote
I've got three helmets. My Arai Corsair (motorcycle helmet) is about 3.4 pounds. That's not that heavy.
Chuck Skowron
PostPosted: Tue Jan 15, 2013 4:28 am    Post subject: Re: neck support? Reply with quote
......I became unable to keep my head up straight around long/fast turns. It's bad enough that I could barely see where I was going around some turns. I was driving on MG Greens. I use a foam donut from K1 racing.
......#2 The tires I was using today are stickier than most. Mooresville users the Hoosier R60A as the spec tire for their leagues. Do you think I'll have this problem with a harder tire, such as these? Was I just driving on way too much tire?
No one here has touched upon the fact that he was driving on MG Greens, which is one of the softest, grippiest tires you can put on a kart.
I'm not fimiliar with Hoosier kart tires, but I know in Hoosier's other race tires, the higher the number, the harder the compound generally. Therefore, I think the R60, or any other "color" (compound) of MG tire, will be harder than the MG Green, which would mean less grip and, theoretically at least, less G-force on your neck.
C. Skowron
CRG/Spec Honda - #15
Tim Blaney
PostPosted: Tue Jan 15, 2013 6:37 am    Post subject: Reply with quote
No, you don't. Just take the advice of some others who were actually helpful and get yourself in better shape.
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.062122000000002 (35.54%), total time:0.174805, queries:38
