Italian Motors - LB
Brett King Design
KG Plastics - FB
WF Sprocket Size for Road Racing
David McDowell
PostPosted: Wed Jan 09, 2013 11:05 am    Post subject: WF Sprocket Size for Road Racing Reply with quote
What would be a good assortment of a few sprockets for Road Racing?
I'm guessing you would want to start with the largest fronts 20-22 front and smallest rears 64-68 rear?
PostPosted: Wed Jan 09, 2013 1:47 pm    Post subject: Reply with quote
Good guess, a lot depends on the track you're running.
There's an excel spreadsheet here
http://www.southwestkarters.com/?page_id=52
called clutchgears.xls that you can play around with ratios on.
Also check with Benn Herr (he's the man behind southwest karters) since his kid used to run WF at Thunderbird there.
Good luck,
Heartbeat Power, LLC.
David McDowell
PostPosted: Wed Jan 09, 2013 2:34 pm    Post subject: Reply with quote
Tracks will be all the west coast that NCKroadracing runs at.
Rich Huston
PostPosted: Wed Jan 09, 2013 4:57 pm    Post subject: Reply with quote
I ran a 21 driver at all the RRs last year. I ran a 21/ 60 at Laguna last year but was on the rev limiter all the way down the back staight. Hope that helps
David McDowell
PostPosted: Wed Jan 09, 2013 4:59 pm    Post subject: Reply with quote
Rich,
Thanks can you guide me to split sprockets under 64T that is the smallest I can seem to find.
David
Bernie Lacotta
PostPosted: Wed Jan 09, 2013 5:50 pm    Post subject: Reply with quote
David McDowell wrote:
Rich,
David
I'm assuming you are talking 219 chain. 53 is the smallest #35 chain sprocket available,64 sounds like the smallest #219 sprocket. It all has to do with the physical size of the sprocket hub. Money can cure all problems in this area but not realistically. A 23 driver (#35 chain)and a 53 axle sprocket will give you a 2.3 gear ratio. Easily enough for most road courses,Daytona excluded. Just for the record I use and recommend #35 chain.
I breathe ,therefore,I race
michael schorn
PostPosted: Fri Feb 22, 2013 3:14 am    Post subject: Reply with quote
IF you are running 219 it is best to get a 23 or 24 driver sprocket. Most of the west coast tracks ratio will be 2.7-2.9 to 1 ratio.
OK everyone It's my opinion only, no one elses, and does not reflect any organization or office that I belong to or hold. Thank you for your support.
Portland Karting Association
Host 2013 IKF 4 Cycle Sprint
& Road Race Grand Nationals
DB time: 0.158597 (45.91%), total time:0.345453, queries:38
