SKUSA (non-flash) - LB
RLV - SS
pavesi shifter not selecting gears
Goto page 1, 2  Next
bonjella martin
PostPosted: Tue Jan 08, 2013 9:08 am    Post subject: pavesi shifter not selecting gears Reply with quote
Hi, iv recently bought my first kart, pavesi 125 brm, think its 2002. Its a brilliant machine, iv only taken it out three times and it was faultless. I changed the gear and clutch oil (wet clutch) and not knowing mutch i left it in neutral when i changed the oil and now it wont go into gear. Not sure how to solve it.
Id appriciate any advice. Thanks
Jim
Paul Makarucha
PostPosted: Tue Jan 08, 2013 10:55 am    Post subject: Reply with quote
spin the axle (assuming engine is mounted. if not, spin the output shaft/gear), pull/push the stick, hard
CKR/KZ
CRG/ICA
http://Jaymotorsports.com
bonjella martin
PostPosted: Tue Jan 08, 2013 11:12 am    Post subject: Reply with quote
i tried spinin the axel, tried bump starting and ramming the gear leaver for over an hour and nothing happens, doesnt even find the neutrals. Also spun the crank over with a drill and fired it up for a few mins but none of that has worked. thanks for your input Smile
James Shafer
PostPosted: Tue Jan 08, 2013 1:18 pm    Post subject: Reply with quote
Sounds like the shift adjustment bolt on the back of the engine case may need attention. Moving the bolt in or out adjusts the shifting mechanism.
You need to play with it until the gearbox shifts properly. When you find the correct postion, secure the bolt with locktite.
jim
Power Stroke Motorsports
bonjella martin
PostPosted: Tue Jan 08, 2013 1:25 pm    Post subject: Reply with quote
ok will have a look at that. so you dont think its down to the oil change? just a coincidence its stopped working after that? will be happy if its as simple as a bolt Smile
Michael Taksa
PostPosted: Tue Jan 08, 2013 1:46 pm    Post subject: Reply with quote
Did you remove the motor to do an oil change? Could it be the linkage/j-arm issue?
James Shafer
PostPosted: Tue Jan 08, 2013 2:42 pm    Post subject: Reply with quote
An oil change in itself would not affect the shifting.
Jim McMahon
PostPosted: Tue Jan 08, 2013 4:27 pm    Post subject: Reply with quote
+1, this is what I am thinking. Your shift lever on the transmission might be sitting at a funny angle.
Jason Berry
Advertiser
Advertiser
PostPosted: Tue Jan 08, 2013 5:43 pm    Post subject: Reply with quote
What bolt or plugs did you remove to add the oil? Posting a photo would be helpful.
www.shopswedetech.com
www.swedetechracing.com
www.swedetechracing.com/news-events-blog/
www.facebook.com/Swedetech
bonjella martin
PostPosted: Wed Jan 09, 2013 4:15 am    Post subject: Reply with quote
i cant post a picture today, camera is broken. i didnt revove the engine atall, but i may have put the wrong amount of oil in. i removed both drain and fill plugs then filled until they reached the drain height. following the guide from http://www.swedetechracing.com/tech_tips/tech_tips_icc_pavesi.html#Area%20oil i used near enough what they said.
i havent changed anything deliberately on the shift angle so think that shud b fine, will still check tho.
other than this i have changed nothing to the kart. thanks
bonjella martin
PostPosted: Thu Feb 28, 2013 11:57 am    Post subject: Reply with quote
finally worked out what it is. theres a nut on the gear box next to the breather which i had tightened up too much and that stopped it going into gear. i loosened it off and now it shifts again Very Happy
do the best with what you have
Bernard Muminovic
PostPosted: Fri Mar 01, 2013 6:23 am    Post subject: Reply with quote
Are you referring to the small allen bolt that's screwed in by a small nut screw? if so, that allen bolt has to be turned a specific amount. I forget how many turns. Maybe someone can chime in. I did this one time on one of my Maxter motor's and it was hard to get into gear.
www.KartingConnect.com
www.neShifterKartSeries.com
www.facebook.com/neshifterkartseries
bonjella martin
PostPosted: Sat Mar 02, 2013 4:07 am    Post subject: Reply with quote
yes, that sounds right bernard. not sure how many times to screw it back. i think there was a small 1 mm space from fully tightned. does it vary position from each gear box or is there one setting for all? it worked perfect before i messed with it
Bernard Muminovic
PostPosted: Mon Mar 04, 2013 5:45 am    Post subject: Reply with quote
I believe every engine is different. But find out what it's suppose to be set to so you can shift nice and smooth.
bonjella martin
PostPosted: Mon Mar 04, 2013 2:25 pm    Post subject: Reply with quote
anyone know were to get pavesi manuals? cant seem to find them online
Goto page 1, 2  Next
Page 1 of 2
DB time: 0.123162 (36.36%), total time:0.33871, queries:38
