Dan Breuer
Posted: Sun Jan 06, 2013 4:04 pm Post subject: Leopard starter relay |
I am new to TaG racing and recently had a couple of starter issues; believe I have a bad starter relay and wondered if it is a common problem. Kart would not start, started with external starter seemed to run fine but the mychron data went heywire. Finally checked battery and etc, found it had 12 v to starter all the time (key off). I took starter apart (broken brush wire), but have not had a chance to get a starter relay yet. Would the relay cause the mychron data (rpm reading) to act crazy?
Thanks for the help,
Dan |
