Ocala Gran Prix - LB
MG Tires - SS
KG Plastics - FB
Low profile seat washers/bolts?
Tim Reed
PostPosted: Sat Jan 05, 2013 10:02 am    Post subject: Low profile seat washers/bolts? Reply with quote
Any suggestions on low profile seat washers/bolts for holding weights on? Would prefer something almost flush to the seat if possible...
Thanks.
Matt Dixon
PostPosted: Sat Jan 05, 2013 10:15 am    Post subject: Reply with quote
http://www.fastech-racing.com/ribtect-seat-mounting-kit-the-original.html
Matt Dixon
94y Energy Corse/Swedetech
PostPosted: Sat Jan 05, 2013 10:22 am    Post subject: Reply with quote
http://www.cometkartsales.com/store/chassis/cpa/metdrillbolt.htm
Get long ones, pre-drilled is good.
And a supply of these.
http://www.cometkartsales.com/store/chassis/cpa/b%26fconical.htm
Cheers,
Heartbeat Power, LLC.
Mark Erpelding
PostPosted: Sat Jan 05, 2013 10:50 am    Post subject: Low profile bolts Reply with quote
Tim go to the local Fastenal and purchace some elevator bolts. They have a completely flat on them approx 90 thousanths. You can grind a flat on the end of the threads if you want to. Not neened it you double nut with regular nuts however if you use nylocks on them it is easier to hold them from spinning when you run the nut up the threads. Google elevator bolts and you can see how flat the heads are.
We spend our money on Racing, Whiskey, and Women ~ The rest we waste!
Tim Reed
PostPosted: Sat Jan 05, 2013 10:53 am    Post subject: Reply with quote
I like these! Might cost $1000.00 with all the lead I have, though. . .
Tim Reed
PostPosted: Sat Jan 05, 2013 10:54 am    Post subject: Reply with quote
Cheers,
This is basically what we are using today... just leaving a lot of welts on my driver... keep in mind, we have about 60 lbs of lead on the seat... and a little driver with no built in "padding"...
Tim Reed
PostPosted: Sat Jan 05, 2013 10:55 am    Post subject: Re: Low profile bolts Reply with quote
I will check it out...
PostPosted: Sat Jan 05, 2013 11:35 am    Post subject: Reply with quote
If the driver is getting beat up by the weight mounts I would make sure you have a proper fitting seat. I have also used high density foam duct taped inside the seat to provide more comfort and a snugger fit. The driver really shouldn't be moving around enough in the seat for this hardware to cause a problem. People often make the mistake of sizing a seat based on what's comfortable, they need to be snug to work right. IMHO, drivers need to understand racing isn't about being comfortable, it's about being fast....
One of the side benefits of taking your kids racing is it toughens them up Wink
Good luck,
John
Cheers,
Brent Harper
PostPosted: Sat Jan 05, 2013 11:40 am    Post subject: Reply with quote
Call Robby Mott... He may sell you some of his long bolts with the smooth head. Very low profile... I got a couple of kits and they are great. Quit rubbing holes in my suit too..
SWISS HUTLESS SWISS I/CMC ROTAX
Tim Koyen
Advertiser
Advertiser
PostPosted: Sat Jan 05, 2013 1:52 pm    Post subject: Reply with quote
Tim,
When TJ was little, I used that dense foam floor padding that you can buy in lock together squares. Its about 1/2" think and does a nice job of both fitting the seat tighter and keeping the weight heads from digging in. Its also dirt cheap. Smile
When he got older, he just switched to a Kevlar Tillet ribvest and that covers most of it. He still used a piece or two of the foam when he feels a little loose in the seat.
www.kartlift.com
www.facebook.com/kartlift
Scott Heavin
PostPosted: Sun Jan 06, 2013 4:03 am    Post subject: Re: Low profile bolts Reply with quote
That's what I use and have for years. An easy way to keep them from spinning during install / removal is to grind a tiny bit off each side of the head to give you two flat areas to get a hold on them with an adjustable wrench. Just be sure to sand your edges after you cut them. Same concept as Mark's cut - just on the other end.
Spec TaG Masters @ NCMP / #23
Jeb Woods
PostPosted: Sun Jan 06, 2013 11:20 am    Post subject: Reply with quote
+1
paul rees
PostPosted: Sun Jan 06, 2013 11:23 am    Post subject: BOLTS Reply with quote
http://www.boltdepot.com/images/length/elevator-bolt-length.gif I use these bolts with thin 2" alum washers. Then a layer of alum speed tape over the top of bolt and washer.
DB time: 0.187435 (45.72%), total time:0.409986, queries:38
