Margay Racing
Brett King Design
Engine output shaft ratio?
Goto page Previous  1, 2
Randy Mckee
PostPosted: Thu Jan 03, 2013 6:31 pm    Post subject: Reply with quote
Might need to account for the difference in powerband and useful top end for various motors. ICC's (KZ) tend to rev much higher than a stock honda; 12700 rpm used for gearing a stock honda will have to be converted to around 14,000 to 15,500 for most ICC's to arrive at the right gear for the fastest straight. Just another wrench to throw at the problem.
Are you creating a spreadsheet to calc some of this? I have a couple spreadsheets from John Denman (I think?) that take care of most of this trickery and allows comparing several gear sets at once.
Randy
Benn Herr
PostPosted: Thu Jan 03, 2013 6:42 pm    Post subject: Reply with quote
Each shifter engine out there can have a different primary and top gear ratio. Some people run the CR125 with the 5 speed still in it. Yamaha, Kawasaki, the Italians, etc... each have a little bit different internal gearing. Our CR250 run 5 speeds plus our top rpm is a lot lower then the 125 boys. It's fun when somebody comes by looking for help with their gearing and ask what you're running!
Here is part of the chart we use. It's the ratio we run on our shortest track (1.25 miles). I generally gear for a certain top speed and let the lower ratios take care of the corners. It's quite a change from the Mac days when you geared to get off the corner and then let the engine scream for the top end.
Engine Axle Drive Ratio
23.00 26.00 1.13
Gear RPM Ratio Input Output RPM after Shift MPH at Shift
1st 10000 1.800 15 27 ~ 54.10
2nd 10000 1.471 17 25 8169.93 66.22
3rd 10000 1.211 19 23 8231.58 80.45
4th 10000 1.000 21 21 8260.87 97.38
5th 10000 0.870 23 20 8695.65 111.99
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
PostPosted: Thu Jan 03, 2013 7:49 pm    Post subject: Reply with quote
That would also depend on the optimum RPM operating range.
You'll find out quickly, what works for one guy/motor, won't necessarily work for another....
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
al nunley
PostPosted: Thu Jan 03, 2013 10:11 pm    Post subject: Reply with quote
23.00 26.00 1.13
Good information, thank you. What engine are we talking about? By the way, the engine to axle ratio is 0.980
Benn Herr
PostPosted: Thu Jan 03, 2013 11:19 pm    Post subject: Reply with quote
2002 CR250 on a Sprinter or a Superkart, the gearing is about the same.
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Page 2 of 2
DB time: 0.069779 (39.2%), total time:0.17803, queries:38
