OTK - LB
Brett King Design
Franklin / Merlin USA - FB
torque down bottom end nuts
Ray Lovestead
PostPosted: Tue Jan 01, 2013 10:27 am    Post subject: torque down bottom end nuts Reply with quote
Man, that title sounds weird.
I just read an snippet talking about the importance of not holding the opposite sides of your crank when torquing down the nuts (either side, stator or clutch).
The problem being that you are basically ruining the balance of the assembly (the run out).
I have seen people use an impact wrench in my own shop!! (it was me, I do it all the time)
Is this a terrible and unforgivably lazy thing to do? Am I ruining my life? Is this the end?
Ray
"Karting Expert Since 2014"
Jim McMahon
PostPosted: Tue Jan 01, 2013 10:36 am    Post subject: Reply with quote
A small impact not so bad so long as you dont hold the other side of the crank and use it sparingly. Ideally you want to either have a piston stop or a counterhold depending on what you are working on.
Its not too late for you, you can repent!
Ray Lovestead
PostPosted: Tue Jan 01, 2013 10:46 am    Post subject: Reply with quote
I don't know what a piston stop or a counter hold is..
(CR125)
Ray
PostPosted: Tue Jan 01, 2013 11:16 am    Post subject: Reply with quote
Some nylon rope pushed into the cylinder through the spark plug hole will work as well.
Cheers,
Heartbeat Power, LLC.
DB time: 0.148757 (44.77%), total time:0.332298, queries:38
