MaxSpeed - LB
Streeter - SS
Wheel Balancer
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Parts
Jordan Tetzlaff
PostPosted: Tue Jan 01, 2013 9:43 am    Post subject: Wheel Balancer Reply with quote
http://www.accelerationkarting.com/wheelbalancer.aspx
CNC machined from billet aircraft aluminum to the tolerance necessary for perfect wheel and tire balancing. Ultra free spinning bearings take the guess work out of wieght placement.
This can only balance a tire that is on a wheel that has a 17mm bearing inside. To balance a rear wheel you can either purchase the adapters or even purhase a 17mm Wheel Hub. The 17mm wheel hub would be more cost effective if you have karts with different sizes of rear axles.
Price includes the "Hub" to balance bolt on wheels
35.00
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Parts All times are GMT - 8 Hours
DB time: 0.163122 (48.63%), total time:0.335404, queries:38
