Jose Pablo Arias
Posted: Fri Dec 28, 2012 4:06 pm Post subject: CRG fuel tank installation |
Hey, i'm new on this forum, i'm from Costa Rica so please be patient with my english.
I've CRG Road Rebel 2009 chassis, and i need to replace the fuel tank because it's cracked. I've already taken the bad one, and 2 days ago i got the new one.
The problem is i cannot find the way to put in on the chassis.
Maybe some video will help me...
Thanks! |
Jimmy McNeil
Joined: 12 Apr 2006 Posts: 1461 Location: United States, California, visalia
Posted: Fri Dec 28, 2012 6:40 pm Post subject: |
Jose, you mite have to take the bolt out of the steering shaft support, raise the steering shaft then install the gas tank.
Hope this helps. |
Ted Murphy
Joined: 17 May 2010 Posts: 40 Location: Canada, ontario,
Posted: Sat Dec 29, 2012 8:39 am Post subject: |
The tank slides in from the engine side, not the master cylinder side. Turn the steering wheel fully to the left to raise the right side tie rod out of the way. Then position the tank into the steering column first, then twist it in the rest of the way. It is tight and the tank will rub on the floor tray but thats ok. You should not have to remove or loosen any parts to do this.
Hope this helps.... |
Jimmy McNeil
Posted: Sat Dec 29, 2012 11:56 am Post subject: |
| Quote: | | You should not have to remove or loosen any parts to do this. |
Not a chance you can get the tank in or out of my kart without loosening any parts. It depends on how high or low you have your steering shaft, mine is all the way down. The only way you could get the tank out without taking the bolt out of the steering shaft support is to remove the floor pan.
Ted Murphy
Posted: Sat Dec 29, 2012 4:47 pm Post subject: |
| Jimmy McNeil wrote: | | Quote: | | You should not have to remove or loosen any parts to do this. |
Not a chance you can get the tank in or out of my kart without loosening any parts. It depends on how high or low you have your steering shaft, mine is all the way down. The only way you could get the tank out without taking the bolt out of the steering shaft support is to remove the floor pan |
Well Jimmy, I guess it is chassis dependent then. I have owned 4 CRG chassis and was able to remove and install the fuel tank without removing or loosening anything on all of them. 2 of those chassis even had a 3rd, lower, hole drilled for the steering column. |
Jimmy McNeil
Posted: Sat Dec 29, 2012 7:04 pm Post subject: |
| Quote: | | I guess it is chassis dependent then |
Its not chassis dependent, it just depends on how low you like your steering wheel. The pic I posted is kinda small but if you look close, theirs about 1/8'' between the shaft and the tank. If I raised the steering shaft all the way up, their would prob be 2'' between them.
| Quote: | | 2 of those chassis even had a 3rd, lower, hole drilled for the steering column. |
My steering shaft is low, like I stated earlier, and im using the top hole in the chassis. It depends on how you install the steering shaft support. |
Jose Pablo Arias
Posted: Tue Jan 01, 2013 12:05 am Post subject: |
Hi! I was unable to install the fuel tank without loosening any parts. I tried to take the bolt out of the steering shaft support but one of the bolts was unscrewed. Finally i've to take the floor tray to install the tank.
Thanks for the help buddies!
P.D. I've bought the fuel tank in comet, i've get a 8.5 liters tank but i think it's a little bit smaller than my original CRG Road Rebel 2009 tank. |
