Ocala Gran Prix - LB
MG Tires - SS
A GUESS ?
JIM SILVERHEELS
PostPosted: Thu Dec 27, 2012 5:47 pm    Post subject: A GUESS ? Reply with quote
Anyone care to guess how much HP the battery charging coil takes away from a Leopard motor? just wondering as usual
jeff grose
PostPosted: Thu Dec 27, 2012 6:21 pm    Post subject: Reply with quote
Funny you mention that Jim, I was thinking the same thing last night, why worry about self charging a battery that I keep a float charge a few days prior to a race, besides we use a external starter all the time and pray that the onboard works when needed.
jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
JIM SILVERHEELS
PostPosted: Thu Dec 27, 2012 6:39 pm    Post subject: MY GUESS Reply with quote
My guess .05 hp. assuming it's got a 3 amp charger.. dont know if it does.
1 hp equals 746 watts so 3 amps times 12 volts divided by 746 would be about .05 hp.
jeff grose
PostPosted: Thu Dec 27, 2012 7:14 pm    Post subject: Reply with quote
whoa now Jim, I wasn't thinking about it that hard Confused but if .05 hp is worth 1000th of a sec. I'll take it, Very Happy
just cause I work at the space center don't mean I'm a rocket sciencetist
jlgracing
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Russell Stevens
PostPosted: Fri Dec 28, 2012 4:25 am    Post subject: Reply with quote
That extra power shows up as a TUR-BOW-BOOST on a Rotax. Rotax guys are all sandbagging to keep the weight off... True story!
JIM SILVERHEELS
PostPosted: Fri Dec 28, 2012 4:35 am    Post subject: RUSTY Reply with quote
Rusty, with the Rotax, they're taking the power generated by the coil and feeding it to the starter and then engaging the starter to help the Rotax motor put out more power. A sly trick by the Austrians. our secret
Russell Stevens
PostPosted: Fri Dec 28, 2012 2:16 pm    Post subject: Reply with quote
Gotcha, that explains why bendix lasts so much longer than on the Leopard. Learn something new every day, now if you will excuse me I need to swap out my power band, and lube the muffler bearings. Laughing
PostPosted: Fri Dec 28, 2012 3:43 pm    Post subject: Reply with quote
I think you might only see a gain when the battery is charging. I'm just comparing it to a belt driven alternator. When the battery is charged and with nothing else drawing power the alternator isn't consuming as much HP as it is when it's putting out. So you might get near the same gain simply by making sure the battery is fully charged.
KURT RODGERS
PostPosted: Fri Dec 28, 2012 4:28 pm    Post subject: Reply with quote
no, no, no! Mad
it's 2 tenths! IT'S ALWAYS 2 TENTHS! Twisted Evil
JIM SILVERHEELS
PostPosted: Fri Dec 28, 2012 6:18 pm    Post subject: Brian Reply with quote
Brian, yer a thinker, the key start RL does have a voltage regulator and as you say, if it's not charging, it aint robbing hp. You may skip any homework assignment tonite me boy !
DB time: 0.145502 (42.04%), total time:0.346139, queries:38
