MIR Racewear - LB
Top Kart USA - SS
Franklin / Merlin USA - FB
MicroMax engine temp 120
Goto page Previous  1, 2
william keyes
PostPosted: Wed Dec 26, 2012 1:59 pm    Post subject: Micro Reply with quote
Spec Gear Very Happy
PostPosted: Wed Dec 26, 2012 4:40 pm    Post subject: Reply with quote
The gearing will depend on the track, the weight of kart and driver and a little on driving style. I don't know what your top RPM should be but if your high you might be geared wrong for your specific parameters. Plug reading will tell you a lot just be sure to run at least 7 or so laps then shut down without much idling and check it.
Andy Seesemann
Expert
Expert
PostPosted: Wed Dec 26, 2012 5:54 pm    Post subject: Reply with quote
Brian,
The MicroMax runs a spec gear. 14/73.
A
Andy Seesemann
FULL THROTTLE KARTING
Orange County, CA.
www.fullthrottlekarting.com
Rotax Challenge of the Americas
www.rotaxchallenge.com
WKA District 10 Trustee
www.worldkarting.com
Really Good Guy.
PostPosted: Wed Dec 26, 2012 7:05 pm    Post subject: Reply with quote
Thanks I didn't know that.
Marshall Martin
PostPosted: Fri Dec 28, 2012 5:13 am    Post subject: Reply with quote
Quote:
we are turning 9800 rpm
If you are turning 9800 something is not adding up. If you are way rich you should not be able to get that kind of rpm in a Micro Max. The RPM is possible but should only happen if the motor is tuned right.
I will again suggest you verify the readings on the gauge somehow.
Marshall Martin
LSR Motorsports
www.lsrmotorsports.com
marshall@lsrmotorsports.com
al nunley
PostPosted: Fri Dec 28, 2012 7:17 am    Post subject: Reply with quote
[quote="Marshall Martin"]
Good thoughts.
You could put the prob in boiling water, Depending on you elevation, the reading should show you if the gauge is close.
Page 2 of 2
DB time: 0.077227999999999 (41.47%), total time:0.186244, queries:38
