Acceleration - LB
K1 Speed - SS
Leading Edge Motorsports
CR125 water pump reassembly help?
Todd Kageals
PostPosted: Sat Dec 22, 2012 3:17 pm    Post subject: CR125 water pump reassembly help? Reply with quote
Guys,
I am nearly complete with my '99 CR125 rebuild but I have run into a couple of snags and have a couple of questions:
1. Is there a washer on the end of the water pump drive shaft? I'm talking about the far end that sits in the small bearing that is in the case, not the end with the impeller on it. The parts diagrams do not show a washer but the service manual does show a washer????? If someone can confirm that there is supposed to be a washer, I would GREATLY appreciate it if you would measure it (a part number would be helpful too).
2. The pentagon shaped washer on the clutch....is is supposed to go with the little fingers facing out or back toward the engine? On my '94 spare it is facing out and is bent down over the nut. But the parts diagrams show the fingers facing back towards the engine. Anyone know for sure?
Thanks for the help.
Todd
Todd Kageals
PostPosted: Sat Dec 22, 2012 5:55 pm    Post subject: Reply with quote
Well....figured out the clutch nut/washer on my own. Still need help with the water pump shaft (washer on the cylinder end or no???).
Vernon Head
PostPosted: Tue Jan 01, 2013 8:24 pm    Post subject: Reply with quote
Do you mean underneath the drive gear? Yes.
Jason Berry
Advertiser
Advertiser
PostPosted: Tue Jan 08, 2013 5:38 pm    Post subject: Reply with quote
- Clutch lock washer has two fingers that face towards the base of the inner hub and while straddle one of the ribs. Keeps washer from spinning. The extended edge of the washer is bent up to secure the nut in place.
- Under the impeller, there is a copper washer between the impeller and the shaft.
www.shopswedetech.com
www.swedetechracing.com
www.swedetechracing.com/news-events-blog/
www.facebook.com/Swedetech
DB time: 0.19032 (50.73%), total time:0.37514, queries:38
