MaxSpeed - LB
Top Kart USA - SS
Electric kart ?
mike clements
PostPosted: Fri Dec 21, 2012 9:21 pm    Post subject: Electric kart ? Reply with quote
I have seen a few videos of very powerful electric karts on youtube.com . Does anyone here know the recipe for building one of these ? Fork lift motor ? Golf cart motor ? Battery weight ? I just want to build one to say I have it. But, I want it to boil the tires !
thanks,
Mike
Began kart racing 1959. Made many friends along the way.
Jim McMahon
PostPosted: Sat Dec 22, 2012 9:48 am    Post subject: Reply with quote
The fork lift motors weight a lot plus batteries. Its not cheap to to it right with LiFE batteries, but if you wanted to just use SLA's it probably wouldn't be too bad. Power isnt a problem, its range\weight thats the issue.
Here's some links:
http://ekartingnews.com/viewtopic.php?t=92586
http://www.diyelectriccar.com/forums/showthread.php?t=60039&highlight=kart
http://www.sodikart.com/en/passion-bercy-erdf-masters-kart-2011.html
Jerry Pretti
PostPosted: Sat Dec 22, 2012 10:30 am    Post subject: Reply with quote
A group of electric karts participated in a recent Redline Oil series race:
http://www.redlineoilkarting.com/?p=1956
I suspect Steve Cameron (the promoter) can put you in touch with some folks in that group.
Jim McMahon
PostPosted: Sat Dec 22, 2012 10:57 am    Post subject: Reply with quote
Here's a nice starter build. try not to laugh too much when he says it handles great and then shows 40lbs of lead hanging off the rear
http://www.youtube.com/watch?v=fOrTQC3Z9uM&feature=youtu.be
David Lehmann
PostPosted: Sat Dec 22, 2012 12:03 pm    Post subject: Reply with quote
Mike,
I have one that we had for evaluation for our indoor track. It's for sale on my web site http://ultra-kart.com/rentalkarts.aspx
I could provide some pictures with the body work off.
Dave Lehmann
Ultra-Kart
AMV Karts, Wheels & Components
Josh Buttafoco
PostPosted: Sat Dec 22, 2012 1:17 pm    Post subject: Reply with quote
Red Line Oil Karting Championship will actually be running a full season Spec electric kart class in 2013.
Brad Linkus
PostPosted: Wed Dec 26, 2012 5:36 pm    Post subject: Reply with quote
This is what you want:
http://www.kartelec.com/f/actu/110504_Linde.htm
http://www.engines4racing.com
engines4racing@msn.com
http://www.coloradokartracing.com
http://www.imimotorsports.com
jeff grose
PostPosted: Wed Dec 26, 2012 5:49 pm    Post subject: Reply with quote
well that's great if all you want to do is go around in circles Rolling Eyes that damn thing even has a reverse, it just ain't natural
jlgracing
#31 Gillard/PDBAmerica
IAME Leopards by P1 Engines
Tag Sr./FKCS/WKA
Driver: Jesse Grose
Ted Hamilton
PostPosted: Wed Dec 26, 2012 7:11 pm    Post subject: Reply with quote
Electric pocketbikes have pushed the power to weight ration for electric racing in our weight range higher than it might otherwise be. Hot setup seemed to be a min. 48V system driven by a programmable controller and Briggs ETek motor... Brushless and LiPo's are probably the way to go unless you can find a reasonable hydrogen fuel cell system. I wonder how the Google JuiceBox or whatever it was would work...
Owner, www.hamiltonhelmets.com // UAS Racer #76 // Karting for karting's sake...keep it fun!
mike clements
PostPosted: Sat Dec 29, 2012 7:46 pm    Post subject: Reply with quote
I saw a mini bike towing a Jr Dragster at the track. The mini bike had a standard Burris electric starter with a gear on the shaft and a chain run to the rear sproket. There was just an on-off button. Looked like fun.
Chris Hurst
PostPosted: Sun Dec 30, 2012 2:13 pm    Post subject: Reply with quote
That Linde E1 looked really fast and it had the weight where I would expect the weight to be (i.e. not hanging 40lbs behind the rear axle) the only thing that caught my eye in the spec sheet was the 160kg of weight EXCLUDING the driver. Thats ~352 lbs. Isn't that rather heavy for a kart without a driver?
Add the average 150lb racing driver and you are up to 502lbs. How much is that going to take away from a kart in transitional sets and linked multiple corners (a track like Grange for example).
Granted it did accelerate incredibly fast off the line so I'm sure corner exit in this thing would make up for some of the added weight, especially in tight corners where you have instant torque.
Thoughts?
DB time: 0.137406 (40.41%), total time:0.340068, queries:38
