Margay Racing
K1 Speed - SS
Assembly lube on main crank bearings before dropping in?
Greg Narvas
PostPosted: Thu Dec 20, 2012 9:28 pm    Post subject: Assembly lube on main crank bearings before dropping in? Reply with quote
Currently rebuilding my cr125 stock moto. I'm about to install my crank bearings but do I need to apply assembly lube on the outer bearings before dropping them in or do they drop in dry?
PostPosted: Fri Dec 21, 2012 4:48 am    Post subject: Reply with quote
If your rebuilding a stock moto, then you're using OEM Honda bearings, right? They have a chunk of lube inside them, I usually flush that out. A 2 stroke motor carries oil in it's fuel, it can't run without fuel, so if the motor fires, that means that fuel/lubrication has already washed the bearings.
CR
East Coast Super Kart Series
"This is how we roll!"
"Home of Cobalt Superkarts"
www.CR2MotorSports.webs.com
Last edited by Chris Reinhardt on Fri Dec 21, 2012 9:53 am, edited 1 time in total
Sam Zavaglia
PostPosted: Fri Dec 21, 2012 6:42 am    Post subject: Reply with quote
Chris Reinhardt wrote:
If your rebuilding a stock moto, then you're using OEM Honda bearings, right? They have a chunk of lube inside them, I usually flushing that out.
Here is an obvious tip, flush out the new crank bearings BEFORE removing the old bearings from the cases.
A couple of nights ago I heated up a set of cases, dropped out the old bearings and while the cases were still warm, dropped in the new bearings.......then I noticed and said fu*k it, I couldn't be bothered washing out the oem grease now. Laughing
www.samzavaglia.com
Bill Pyles
PostPosted: Tue Dec 25, 2012 6:26 pm    Post subject: crank installation Reply with quote
I always have the crankshaft bearing journals sanded down on a lathe to the point where a main bearing slip-fits onto the journal at room temperature. You will of course have to heat the case halves and cool the bearings to install the bearings into the case halves, but with the crank journals sanded, the crank will drop into the bearings easily so you can torque the case halves together without bending the crank.
Bill Pyles
Phoenix AZ
andy graham
PostPosted: Wed Dec 26, 2012 5:00 am    Post subject: Reply with quote
put the bearings in the freezer overnight, they'll drop right in.
Greg Narvas
PostPosted: Wed Dec 26, 2012 9:46 am    Post subject: Reply with quote
ok thanks guys. But from what I'm understanding, there should be no lube on the outer part of the bearing (where the bearing meets the case itself)?
Benn Herr
PostPosted: Wed Dec 26, 2012 10:48 am    Post subject: Reply with quote
Right, clean and dry on the outside of the bearing. Make sure the case is free of debris too.
Benn Herr
beherr3@cox.net
Kart Design
Chandler, Az.
Sam Zavaglia
PostPosted: Wed Dec 26, 2012 7:30 pm    Post subject: Reply with quote
That could work but I have to finish the job today, not tomorrow morning. Laughing
Still need to get the old bearings out of the cases, at that same time could be a good time to put the new ones in. Wink
www.samzavaglia.com
J.R. Clasen
PostPosted: Fri Jan 04, 2013 12:49 pm    Post subject: to lube or not to lube Reply with quote
Lubricating the bearing outer surface is always a good idea, espceially when the two mating surfaces are dis-simular metals (alum & steel in this case). This will make it a lot easier when you have to press the bearings out the next time you rebuild.
As suggested earlier, put the bearings in the freezer over night; heat the cases to the point you have to pick them up with a shop towel, and then drop the bearings in. Make sure you have a soft mallet standing by just in case you get one crossed up when you drop it in, they can get stuck pretty quickly so sometimes you need to give 'em a tap in. No metal hammer though!
JR
DB time: 0.1449 (42.51%), total time:0.340856, queries:38
