SoCal Sprinters
MG Tires - SS
2007 Trackmagic FTR/YZ-125
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Kart Packages
James Frank
PostPosted: Wed Dec 19, 2012 7:29 am    Post subject: 2007 Trackmagic FTR/YZ-125 Reply with quote
Turn-key 2007 Trackmagic FTR with 2001 and 2000 YZ-125 engines (w/mounts) and BTK large radiator. Both have fresh top end rebuilds. Never seized. Mikuni TMX 38 carb with main jets from 350 - 400. New fuel lines installed.
2 shockwave axles and 1 oem axle. 2 sets Douglas metric non-beadlock wheels with one set lightly used MG FZ yellow tires, 1 set Dunlop KT-8 rain tires/wheels.
Extended and medium rear 50mm Wildkart hubs.
Mychron-2 with dual temp sensors (H20/CHT), tachometer, speedometer, IR lap timer beacon, shift lights and 2 temp warning lights.
Trackmagic steering wheel and Sparco T310 steering wheel. 10-degree steering wheel angled shim installed.
New rear brake caliper, spare front brake pads, spare new master cylinders.
New 2011 updated bodywork plus original CIK bodywork. Fiberglass road course fairing, never installed. Spare used OEM nerf bars. Tillet T8 M/L seat, have Trackmagic struts and additional struts (not currently used)
Spare engine pistons, gaskets, coils, carb boots, new cylinder head.
50mm steel axle sprockets 22t-26t. YZ engine sprockets 14t-19t. This covers any gearing range from 65mph to 105mph top speeds.
Kart Stand also included
Other parts: chassis/engine bolts, brake components, 3-hole RLV airbox with rain hood and angled/straight boots with internal foam filter. Other miscellaneous parts
Kart is located in Huntsville, AL. Will allow local pick-up and can agree to deliver to Nashville/Atlanta/Memphis/Knoxville/Montgomery areas for serious buyers. Buyer will setup shipping for further areas. Additional pictures per request. This is alot of stuff for racing, all you need is a way to haul it to the track
Entire package $5250 or best offer. PM or email frankjd1978@gmail.com (256)975-0055
James Frank
Baker's Creek Kart Club
2009, 2007 & 2004 125cc ShifterKart Champion
Post new topic   Reply to topic    eKartingNews.com Forum Index -> Kart Packages All times are GMT - 8 Hours
DB time: 0.125298 (53.45%), total time:0.234435, queries:38
